Hi, I would like to do something like:
Joystick1yaxis = Motor[1];
Joystick1yaxis = Motor[2];
Joystick2yaxis = Motor[3];
Joystick2yaxis = Motor[4];
how would I go about this?
Thanks
Thanks
have you read http://first.wpi.edu/Images/CMS/First/GettingStartedWithC.pdf and http://first.wpi.edu/Images/CMS/First/WPI_Robotics_Library_Users_Guide.pdf?
I would assume you want something more like this:
robotDrive.TankDrive(stick1,stick2);
But I need two joysticks running 4 motors, 2 motors to each joystick.
Like ByteIt said, you’ll want to do robotDrive.TankDrive(leftJoystick, rightJoystick);
But, the constructor you’ll want to use is:
RobotDrive(SpeedController *frontLeftMotor, SpeedController *rearLeftMotor, SpeedController *frontRightMotor, SpeedController *rearRightMotor, float sensitivity=0.5)
This will give you tank drive for 4 motors from two joysticks.
Good luck!
So now I have:
class RobotDemo : public SimpleRobot
Jaguar frontLeftMotor(1);
RobotDrive drivetrain(SpeedController *frontLeftMotor, SpeedController *rearLeftMotor, SpeedController *frontRightMotor, SpeedController *rearRightMotor, float sensitivity=0.5)
Joystick stick; // only joystick
public:
RobotDemo(void):
myRobot(1, 2), // these must be initialized in the same order
stick(1) // as they are declared above.
GetWatchdog().SetExpiration(0.1);
* Drive left & right motors for 2 seconds then stop
void Autonomous(void)
GetWatchdog().SetEnabled(false);
drivetrain.Drive(0.5, 0.0); // drive forwards half speed
Wait(2.0); // for 2 seconds
drivetrain.Drive(0.0, 0.0); // stop robot
* Runs the motors with arcade steering.
void OperatorControl(void)
GetWatchdog().SetEnabled(true);
while (IsOperatorControl())
GetWatchdog().Feed();
Wait(0.005); // wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
I need help declaring the Jaguars now
This should work. Change the values under RobotDemo(void): to change the slots.
#include "WPILib.h"
RobotDrive robotDrive;
Joystick stick1, stick2;
public:
RobotDemo(void):
robotDrive(1, //Front Left motor port
2, //Back left motor port
3, //Front right motor port
4), //Back right motor port
stick1(1), //Joystick 1 in slot 1
stick2(2) //Joystick 2 in slot 2
robotDrive.Drive(0.5, 0.0); // drive forwards half speed
robotDrive.Drive(0.0, 0.0); // stop robot
If it works, yay! If not, play around with the ports, and make sure everything’s wired correctly. If all of that is correct, I probably did something stupid. XD
So this is what I have right now, we plugged the left motors into pwm 1 and the right ones into pwm 2 using pwm splitter, and still no luck
#include "WPILib.h"
public:
RobotDemo(void):
robotDrive(1,2),
are the joysticks configured correctly on the driverstation?
go to setup tab, and on the right side, drag the joysticks to 1 and 2
Got things working now, thanks for all the help guys!
might i suggest using an ancient technology of split PWM’s the go from one port to 2 jaguars or victors. they are extremely helpful.
We may or may not have ended up doing this…
