Motor controller problem
I connected my Victor SPX to a motor. When I give power to circuit, its color was solid green(the others were red blinking-It is normal). I changed my controller to another spx and tried again. It was working. I turned it off and after 20 min, I turned on again. It wasnt working. And now, when I user another controller in circuit, motor works but the other 2 controllers dont work eventhıugh I change pdp roborio etc. What may be the problem?
If you are using CAN, have you confirmed the CAN ID in Phoenix Tuner?
^^ This. Also double-check the connections, both power and CAN (or PWM).
Assuming these didn’t fix it, what do the lights do now?
