Posted by James Jones.
Engineer on team #180, SPAM, from Martin County & South Fork H.S. and Pratt & Whitney.
Posted on 6/9/99 2:16 PM MST
Does anyone know the pitch of the gears on the motor shafts of the drill motor and FP motor?
Posted by Dave. [PICTURE: SAME | NEW | HELP]
Student on team #308, Walled Lake Monster, from Walled Lake Schools and TRW.
Posted on 6/9/99 6:26 PM MST
In Reply to: motor gear pitches posted by James Jones on 6/9/99 2:16 PM MST:
Well, I know that the Fisher Price motors either had a 16 or a 17 tooth gear on the motor. I don’t know what it was going out of the gear box though.
Dave
: Does anyone know the pitch of the gears on the motor shafts of the drill motor and FP motor?
Posted by Joe Johnson. [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 6/9/99 9:12 PM MST
In Reply to: Re: motor gear pitches posted by Dave on 6/9/99 6:26 PM MST:
I am pretty sure that the pinions on that F-P motor were 16 Tooth, 32 pitch. I am very very sure about the 16 tooth part, I am a bit fuzzy on the Diametral Pitch.
The gear is not quite ‘standard’ but it mates pretty well with standard gears. Increase the center distance by .002 or so to allow for any mismatch in the tooth forms.
Joe J.
By the way, you the D.P of a standard gear is (N+2) / Outer Diameter and some common DP’s are 10, 12, 16, 20, 24, 32, 48, and (way to small of teeth to even THINK about on a FIRST robot
Posted by Raul.
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
Posted on 6/10/99 6:49 AM MST
In Reply to: 16 Tooth 32 pitch… as I recall… posted by Joe Johnson on 6/9/99 9:12 PM MST:
I had a lot of experience with this little pinion this year because we created our own transmission for that motor. Here is what I learned:
First of all, it obviously has 16 teeth. What is not obvious is that it is a metric ‘M0.7’ pitch diameter. I found this out first the hard way and then by finally getting a print of that little gear from Bosch (this was not easy and took quite a while).
At first I also used a standard 32 pitch gear and found that it did not mate correctly. Then, I tried a M0.8 metric gear which was not easy to find. It was even worse. Now, I did not even know that there was such a thing as a M0.7 pitch. All this time I did not have the print telling me the proper size. So, I went back to the 32 pitch and used an off-the-shelf brass gear from Small Parts. Using brass was important to allow the teeth to wear in and not harm the pinion on the motor. One good thing about the pinion is that it is hardened and is very durable.
Anyway, by the time I got the print and realized it was M0.7 I had run out of time and did not want to change our design (redo the gear centers on the mounting plates) because it seemed to be running OK.
Some advise if you use mate a 32 pitch gear: Run it for a while under no load to wear it in. We blew out one gear because we ran it under load in practice without wearing them in. Ever since we wore them in properly, we never broke teeth on those brass gears. It will make a lot of noise at first and will eventually smooth out. And of course, be sure to use plenty of grease.
I’m not sure I agree with Joe about allowing a little extra clearance. In fact, we moved the center .010’ closer than required by standard 32 pitch gears. The standard clearance seemed too sloppy.
In the future, I would try to get the M0.7 gears. I think, Stock Drive Products (516-328-3300) has them
Good luck
Raul
Posted by Raul.
Posted on 6/10/99 6:54 AM MST
In Reply to: 16 Tooth M0.7 pitch posted by Raul on 6/10/99 6:49 AM MST:
: I had a lot of experience with this little pinion this year because we created our own transmission for that motor. Here is what I learned:
: First of all, it obviously has 16 teeth. What is not obvious is that it is a metric ‘M0.7’ pitch diameter. I found this out first the hard way and then by finally getting a print of that little gear from Bosch (this was not easy and took quite a while).
: At first I also used a standard 32 pitch gear and found that it did not mate correctly. Then, I tried a M0.8 metric gear which was not easy to find. It was even worse. Now, I did not even know that there was such a thing as a M0.7 pitch. All this time I did not have the print telling me the proper size. So, I went back to the 32 pitch and used an off-the-shelf brass gear from Small Parts. Using brass was important to allow the teeth to wear in and not harm the pinion on the motor. One good thing about the pinion is that it is hardened and is very durable.
: Anyway, by the time I got the print and realized it was M0.7 I had run out of time and did not want to change our design (redo the gear centers on the mounting plates) because it seemed to be running OK.
: Some advise if you use mate a 32 pitch gear: Run it for a while under no load to wear it in. We blew out one gear because we ran it under load in practice without wearing them in. Ever since we wore them in properly, we never broke teeth on those brass gears. It will make a lot of noise at first and will eventually smooth out. And of course, be sure to use plenty of grease.
: I’m not sure I agree with Joe about allowing a little extra clearance. In fact, we moved the center .010’ closer than required by standard 32 pitch gears. The standard clearance seemed too sloppy.
: In the future, I would try to get the M0.7 gears. I think, Stock Drive Products (516-328-3300) has them
: Good luck
: Raul
