I’ll give it a try:
So from the given data we can write an equation relating current I to speed W:
I = (Istall-Ifree)(1-W/Wfree)+Ifree
We can also write an equation that relates T to W:
T = (Ts)(1-W/Wfree)
Kt = T/I, however if you divide these two equations you get Kt as a function of W, and this is because the equations have different roots. Theoretically they have the same roots as at T=0->I=0, but they do not because the equation for T only takes into account external loads on the motor and ignores the torques due to friction forces in the motor.
So the equation for T really is:
T = (Ts)(1-W/Wfree)-Tloss
Solving I=0 for W gets:
W(I=0) = Wfree(1+Ifree/(Istall-Ifree))
Then plugging that W into Tloss = (Ts)(1-W/Wfree) to solve Tloss gives:
Tloss = -(Tstall*Ifree/(Istall-Tfree))
Plugging Tloss back into T = (Ts)(1-W/Wfree)-Tloss gives us:
T = Ts(1-W/Wfree+Ifree/(Istall-Ifree))
Now since these two equations have the same root, we can divide them and get a constant:
Kt = T(W)/I(W) = -Tstall(Istall/(Ifree-Istall))/Istall
Plugging in for a bag motor yields:
Kt = 0.0102
Ke is much simpler to solve for:
Ke = V/W
However you need to take into account the voltage drop through the motor’s windings at W, so we first need to solve for internal motor resistance which is:
R = Vspec/Istall
We now can rewrite Ke to include this drop:
Ke = (Vspec-I(W)*R)/W
Since we are given Wfree and Ifree we can plug those in along with R and get:
Ke = (Vspec-Ifree*Vspec/Istall)/Wfree
Ke = 0.0078
As to why they are different… I would guess bad measurement, but its more likely I did the calculation wrong
