We have a PG 188 that has a ⅜ hex output. We want to use this to drive a rack and pinion but see on M-C that the pinions are round or keyed shaft.
So what’s the best advice here?
Does anyone sell ⅜ in Hex pinion gears?
Check that the motor is allowed. I don’t think it is.
If it’s not in https://firstfrc.blob.core.windows.net/frc2020/Manual/2020FRCGameSeasonManual.pdf#page85
It’s not allowed.
Then again, if this is not a competition bot, you don’t have to worry about that.
We used it last year but you’re right I don’t see it listed.
Notwithstanding that- any ideas?
I’m going to look at other motors obviously. This is an FRC bot.
Yes, the AndyMark PG motor is on the list; the 188 in that is the (approximate) ratio of the gearbox.
Source: I worked there around the time the PG gearboxes were getting overhauled for hex shafts.
Ah thanks. You might try printing an adapter if you have that capability.
I wanted to pair it with a steel rack for an elevator. So assuming pinion needs to be steel also.
3/8 hex to key shaft adapter. Probably won’t work though.
