motor power
how much psi can i use in each motor?
You don’t use pounds per square inch to run an electric motor. You use volts and amps to run those.
If you’re referring to a pneumatic cylinder, you’re limited to 60 PSI by <R70>, with 120 PSI being allowed for storage tanks upstream of the primary regulator (<R69>).
