We cannot get a falcon500 motor to run on a toggle, instead we have it on a hold for now. The whileTrue() command in the TalonFx class works for the hold, however the onTrue() command, which is supposed to be a toggle command, does not stop the command when the button is pressed again.
This is the code that fails:
package frc.robot;
import frc.robot.Constants.OperatorConstants;
import frc.robot.commands.Autos;
import frc.robot.commands.Shoot;
import frc.robot.subsystems.Shooter;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.button.CommandXboxController;
import edu.wpi.first.wpilibj2.command.button.Trigger;
public class RobotContainer {
private final Shooter shooter = new Shooter();
private final Shoot shoot = new Shoot(shooter);
private final CommandXboxController xboxController =
new CommandXboxController(OperatorConstants.kDriverControllerPort);
public RobotContainer() {
configureBindings();
private void configureBindings() {
//xboxController.a().whileTrue(shoot); - this is the whileTrue() method that works when holding the button
xboxController.a().onTrue(shoot); - this is the method that fails to toggle the motor
* Use this to pass the autonomous command to the main {@link Robot} class.
* @return the command to run in autonomous
public Command getAutonomousCommand() {
// An example command will be run in autonomous
return null;
