Motor's
Posted by Makana.
Student on team #359 from Waialua High School.
Posted on 2/1/2000 5:30 PM MST
Hi,
I was wondering does anyone know the total amount of
motor’s you are allowed to used on your robot and if we
wanted to substitude a drill motor for another motor
could we
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 2/1/2000 5:46 PM MST
In Reply to: Motor’s posted by Makana on 2/1/2000 5:30 PM MST:
As Per Team Update 3, Q/A 66:
You are only allowed to use the number and type of motors in the kit. If you purchase indentical motors from an outside source, you can use them as replacements, but not in addition to the motors in the kit.
Nate
Posted by Joe Johnson.   [PICTURE: SAME | NEW | HELP]
Engineer on team #47, Chief Delphi, from Pontiac Central High School and Delphi Automotive Systems.
Posted on 2/1/2000 5:48 PM MST
You can use all the motors provided in the kit and no others.
There are no motors on the additional list, so all you have are the motors that were provided in the kit and were brought home from NH.
There are 12 motors available (in descending order of peak power available at the output shaft):
2 Bosch Drills/Gearboxes
2 Fisher-Price/Gearboxes
2 Delphi Power Sliding Door Motors (Mfg. Taigene)
2 Globe Motors
2 Delphi Seat Motors (Mfg. Keyang)
2 Delphi Window Motors (Mfg. Valeo, purchaser of ITTA)
I hope this helps.
Joe J.
