I am assuming that the standard Viair compressor can still be mounted sideways according to these otherthreads and this FAQ from Viair.
Can the mounting brackets be turned 90° to better facilitate this sideways mounting? Or is this considered modification of the device? What about using your own custom mounting brackets?
Any change to pneumatic components beyond how they come out of the package is generally considered modification. Unless it is specifically called out in the data or instructions for that product.
We have mounted ours sideways and plan to do so again this year. A flat plate works great for this, or any vertical surface. The more solidly mounted, the more the robot shakes, so don’t lose the small isolation bushings that come with those little brass sleeves to keep the noise reasonable. We use a vertical part of our frame when mounting sideways.
The Viair 90C manual doesn’t state anything about that plate being a “configurable” part that you can remove and re-mount. So, unfortunately, you probably can’t do it. Your best bet is to bend a piece of sheet metal to make your own 90° mount.
