I inserted our robot onto the field in Onshape but I can’t move the elevator up and down to see clearances.
I copied the field from the link at firstinspires.org. Sometimes I can move the robot, but I can’t ever seem to extend the elevator.
Is there a training video I should go watch?
you’ll need to fasten or fix your robot to something so it doesn’t move in order to move the elevator
you can also select a point on the elevator and use the arrow to move the point upwards.
Thanks. I did a planar mate to the carpet, but that prevented me from moving the robot around. I will work with it more tonight.
