MpLab issues!
MpLab won’t compile the project…
i keep getting the error
C:/…/ cannot find “stdio.h”
failed build
big problem, help would be hugely appreciated…
In the IDE, right click on the project in the MCW window (name should be something like default.mcp or gyro.cmp), and select “Build Options”. Make sure the Include Path and Library Path match your C18 installation.
Kaszeta is right, its your include path. From the menu you can also select “Project->Build Options->Project”.
I attached a picture of where the include directory is set in my project.
Brian
Thanks guys, it worked
