Hi chiefdelphi !
I am worried about my code because I cant test it now.
I have motor which when button 4 is pressed it goes forward and if its not pressed it must stop, but also when I press 5 it needs to go reverse and if its not pressed it stops.
So I made the cases but the thing that is worrying me is will false case ( with output = 0 ) effect on other case which needs to spins it reverse when button 5 is pressed…
Here is screen shot
