I’ve been [slowly] putting together localization code in preparation for next year, but I was wondering if it is possible to use multiple limelights (specifically a 3 and 2+) at once with LimelightHelpers.
If not, would it just be easier to do the math ourselves? We already have the math written out for multicam, just not implemented yet.
Code
Yes, we have 4 3Gs so we can always see at least one Tag. It improved our auto consistency and teleop shooting performance significantly.
Yes, this is possible pretty easily. All you would have to do is assign each limelight a different hostname in the LL web UI and pass that into the LimelightHelpers method.
LimelightHelpers.getBotPoseEstimate_wpiBlue("hostname")
I noticed that there is a hardcoded 0.3s offset for latency for each limelight, but you can get more accurate data by using the cl and tl keys through network tables, or use the LimelightHelper methods:
double tl = LimelightHelpers.getLatency_Capture(name);
double cl = LimelightHelpers.getLatency_Pipeline(name);
double fga = Timer.getFPGATimestamp();
this.timestamp = fga - tl/1000d - cl/1000d;
it isn’t absolutely necessary but might improve accuracy.
