My dashboard would not show the color for my color sensor, please help me
package frc.robot;
import edu.wpi.first.wpilibj.I2C.Port;
import edu.wpi.first.wpilibj.util.Color;
import com.revrobotics.ColorMatchResult;
import com.revrobotics.ColorSensorV3;
import com.revrobotics.ColorMatch;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
  • The VM is configured to automatically run this class, and to call the
  • functions corresponding to each mode, as described in the TimedRobot
  • documentation. If you change the name of this class or the package after
  • creating this project, you must also update the build.gradle file in the
  • project.
final public class Robot extends TimedRobot {
private static final String kDefaultAuto = “Default”;
private static final String kCustomAuto = “My Auto”;
private String m_autoSelected;
private final SendableChooser m_chooser = new SendableChooser<>();
private Port i2cPort;
  • This function is run when the robot is first started up and should be
  • used for any initialization code.
@Override
final public void robotInit() {
m_chooser.setDefaultOption("Default Auto", kDefaultAuto);
m_chooser.addOption("My Auto", kCustomAuto);
SmartDashboard.putData("Auto choices", m_chooser);
@Override
final public void teleopPeriodic() {
ColorMatchResult match = m_colorMatcher.matchClosestColor(detectedColor);
SmartDashboard.putNumber("Red", detectedColor.red);
SmartDashboard.putNumber("Green", detectedColor.green);
SmartDashboard.putNumber("Blue", detectedColor.blue);
SmartDashboard.putNumber("Confidence", match.confidence);
SmartDashboard.putString("Detected Color", colorString);
  • This function is called every robot packet, no matter the mode. Use
  • this for items like diagnostics that you want ran during disabled,
  • autonomous, teleoperated and test.
  • This runs after the mode specific periodic functions, but before
  • LiveWindow and SmartDashboard integrated updating.
private final ColorMatch m_colorMatcher = new ColorMatch();
private final ColorSensorV3 m_colorSensor = new ColorSensorV3(i2cPort);
Color detectedColor = m_colorSensor.getColor();
String colorString;
@Override
final public void robotPeriodic() {
  • This autonomous (along with the chooser code above) shows how to select
  • between different autonomous modes using the dashboard. The sendable
  • chooser code works with the Java SmartDashboard. If you prefer the
  • LabVIEW Dashboard, remove all of the chooser code and uncomment the
  • getString line to get the auto name from the text box below the Gyro
  • You can add additional auto modes by adding additional comparisons to
  • the switch structure below with additional strings. If using the
  • SendableChooser make sure to add them to the chooser code above as well.
@Override
m_autoSelected = m_chooser.getSelected();
// m_autoSelected = SmartDashboard.getString("Auto Selector", kDefaultAuto);
System.out.println("Auto selected: " + m_autoSelected);
  • This function is called periodically during autonomous.
  • This function is called periodically during operator control.
You’re not actually creating the port. The line Port i2cPort; should be more like Port i2cPort = I2C.Port.kOnboard;. I hope this helps!
Note: your post looks better when you format your code by surrounding it with backticks :wink:
thanks for the help but its not working
Ah, I see the problem. You need to do two things:
  1. Change this import: edu.wpi.first.wpilibj.I2C.Port to this: edu.wpi.first.wpilibj.I2C
  2. Change private Port i2cPort = I2C.Port.kOnboard; to private I2C.Port i2cPort = I2C.Port.kOnboard;
Thank you for the screenshot!
thanks but this still show up in my screen. * Could not instantiate robot edu.wpi.first.wpilibj.I2C!
  • at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:231)
  • at edu.wpi.first.wpilibj.RobotBase.startRobot(RobotBase.java:348)
  • at frc.robot.Main.main(Main.java:27)
  • Warning at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:244): Robots should not quit, but yours did!
  • Error at edu.wpi.first.wpilibj.RobotBase.runRobot(RobotBase.java:245): Could not instantiate robot edu.wpi.first.wpilibj.I2C!
  • ********** Robot program starting **********
If there aren’t any red lines in your code, it’s probably that the I2C port is already in use.
Is this a blank color-sensor-only program, or a full robot program?
If you put your code on github and post a link you can get better help.
Does the code build?
The error they’re getting suggests that the code builds, but fails to run on the roboRIO.
Agreed with @NewtonCrosby. Please post your code in github or similar so we can look at it.
Also, please post the error you’re currently getting.
