When I add Xbox buttons into my code I am no longer able to use the triggers on the same Xbox controller. Any help would greatly be appreciated.
What do you mean by this? Also if you could post your code it would be helpful.
I mean when I add button controls into the code the triggers on the Xbox controller (RT and LT) not long work
So you don’t see the triggers change when you look at the 4th tab (USB) of the driver station?
Post code it will be easier.
Do not do this. Use the XboxController
Class
hey I found my problem. I was using a global stop function.
