Name of camera task
Hi. Got the camera to the dashboard to work this weekend. Woohoo!
It has around a 2.5 second lag, is this normal, good or bad. I set it to 160 x 120 and tried setting max frames per second to 15. Setting FPS didn’t seem to change the lag.
I noticed that if you kill the robot code, the camera still appears on the dashboard because there is a separte camera task for it. What is this task called? It seems that when a new program is run (in memory for fast debugging) and the camera task is already running, then it won’t reinitialize the camera, plus it sometimes dies with a kernal exemption. Is there a way to stop the camera task from code?
Thanks,
Brian
At the moment, no. You will need to modify WPIlib: (From AxisCamera.cpp)
// TODO: Keep track of this so it can be shut down!
new PCVideoServer();
But to answer your question, FRC_cameraTask and FRC_PCVideoServer
2.5 seconds is bad, did you update the driverstation to 1.1, cRIO to v20 and WPILib to 4.3?
I believe there is something to the effect of a DeleteInstance() function in wpi lib i’m not completely sure of its effects though. I do know that stoping cameras with it didn’t seem to work out too well, and without source infront of me i can’t say much else on it.
as for lag, try decreasing color depth or setting a moderate amount of compression (we use 50).
are you running any image processing? it can slow things down quite a bit.
let us know how it goes
DeleteInstance is for Java, and won’t delete the images to the dashboard, as my previous post says
ah, that explains a lot. Thanks for the clarification.
