NAVX AHRS import error
I would like to use NAVX gyros in my robot code so I downloaded the vendordeps from https://pdocs.kauailabs.com/navx-mxp/software/roborio-libraries/java/ . When I import com.kauailabs.navx.frc.AHRS, VSCode underlines it in red saying “The import com.kauailabs cannot be resolved.” although whenever I build the code there are no issues. However, when I go to make my Gyro object, the build fails saying “AHRS cannot be resolved to a type”. I have the right vendordeps downloaded so I was wondering the cause of this. For reference the code looks like this:
import com.kauailabs.navx.frc.AHRS; //underlined red but builds fine
import org.texastorque.torquelib.base.TorqueFeedback;
public class GyroFeedback extends TorqueFeedback{
    private final AHRS nxGyro; //underlined red and build error
    @Override
    public void update() {
        // TODO Auto-generated method stub
Just to confirm - does “Downloaded” imply you followed the WPI Documentation steps and didn’t have errors while doing so?
Yes, I had no errors when getting the vendordeps
Hey Suhas,
I checked out your code. It built successfully for me and ran in the simulation fine. I see you upgraded the NavX library from 3.* to 4.*, which could be causing an issue. Talk to me tomorrow during the meeting, and I can work with you to fix it.
Thanks, Jack!
Issue was due to Java cache. Fixed by clearing cache and refreshing vendordeps.
