Navx-mxp firmware upgrade issue
I’m on Windows 7 x86.
Downloaded the latest navx-mxp download, installed the setup.exe… for some reason the driver software didn’t install automatically. It took some effort, but I finally installed the drivers manually using the installers in Program Files.
Anyways, got the firmware updater to work. Upgraded using navx-mxp_3.1.344.hex (md5sum 781d54ca7260e0a101a3801cf154851e) , no problems. However, the ‘currently loaded navx-Model firmware version’ shows 3.1.336. Board version 33.
Output from the 'status' when upgrading
Detecting DFU Interface...
DFU device opened OK
Got DFU Descriptor 1
Found VID: 0483 PID: 5740 Version: 0200
Detecting device
Loading the DFU file
DFU file parsed with 1 elements
Opening the device
Performing partial erase
Partial erase complete
Writing block 0
Writing block 1
Writing block 2
Writing block 3
Writing block 4
Writing block 5
Writing block 0
Writing block 1
Writing block 2
Writing block 3
Writing block 4
Writing block 5
Writing block 6
Writing block 7
Writing block 8
Writing block 9
Writing block 10
Writing block 11
Writing block 12
Writing block 13
Writing block 14
Writing block 15
Writing block 16
Writing block 17
Writing block 18
Writing block 19
Writing block 20
Writing block 21
Writing block 22
Writing block 23
Writing block 24
Writing block 25
Writing block 26
Writing block 27
Writing block 28
Writing block 29
Writing block 30
Writing block 31
Writing block 32
Writing block 33
Writing block 34
Writing block 35
Writing block 36
Writing block 37
Writing block 38
Writing block 39
Writing block 40
Writing block 41
Writing block 42
Writing block 43
Writing block 44
Writing block 45
Writing block 46
Writing block 47
Writing block 48
Writing block 49
Writing block 50
Writing block 51
Writing block 52
Writing block 53
Writing block 54
Writing block 55
Writing block 56
Writing block 57
Writing block 58
Writing block 59
Writing block 60
Writing block 61
Writing block 62
Writing block 63
Writing block 64
Writing block 65
Writing block 66
Writing block 67
Writing block 68
Writing block 69
Writing block 70
Writing block 71
Writing block 72
Writing block 73
Writing block 74
Writing block 75
Writing block 76
Writing block 77
Writing block 78
Writing block 79
Writing block 80
Writing block 81
Restarting
Programming complete
I’ve tried multiple times. Am I doing something wrong here? Or maybe the firmware version didn’t get updated correctly in the hex file? Thanks!
Hi dustin,
The firmware hasn’t actually changed since 2017, so even though the firmware number has changed, there’s not any value in updating the firmware. So access to navX-MXP from Python should continue to work as it did before. :slight_smile:
But I really appreciate your letting me know; there was a burp in the build process that slipped through.
