Navx MXP Gyro Simulation in Java
Trying to simulate a Navx gyro and am not having any luck even though the documentation here Java | navX-MXP
states that it is possible.
How do I create the simulation gyro in Java code?
From the documentation:
int dev = SimDeviceDataJNI.getSimDeviceHandle(“navX-Sensor[0]”);
SimDouble angle = new SimDouble(SimDeviceDataJNI.getSimValueHandle(dev, “Yaw”));
angle.set(5.0);
so your simulationPeriodic would look something like:
public void simulationPeriodic() {
  // Set the inputs to the system. Note that we need to convert
  // the [-1, 1] PWM signal to voltage by multiplying it by the
  // robot controller voltage.
  m_driveSim.setInputs(m_leftMotor.get() * RobotController.getInputVoltage(),
                       m_rightMotor.get() * RobotController.getInputVoltage());
  // Advance the model by 20 ms. Note that if you are running this
  // subsystem in a separate thread or have changed the nominal timestep
  // of TimedRobot, this value needs to match it.
  m_driveSim.update(0.02);
  // Update all of our sensors.
  m_leftEncoderSim.setDistance(m_driveSim.getLeftPositionMeters());
  m_leftEncoderSim.setRate(m_driveSim.getLeftVelocityMetersPerSecond());
  m_rightEncoderSim.setDistance(m_driveSim.getRightPositionMeters());
  m_rightEncoderSim.setRate(m_driveSim.getRightVelocityMetersPerSecond());
  SimDouble gyroSimAngle = new SimDouble(SimDeviceDataJNI.getSimValueHandle(dev, “Yaw”));
  gyroSimAngle.set(-m_driveSim.getHeading().getDegrees();
I think you could also have gyroSimAngle as a global variable in your drive class so you are not redeclaring it every time
