NavX MXP initialization
Hello everyone,
I hope all of your builds are going well. My team is using the NavX MXP again (we used it last year) but initialization is proving to be a pain. Our code can be found on GitHub but the basics are as follows:
We have a header file (PenguinEmpire.h) with our robot class declaration, including the line
AHRS *ahrs;
In our source file, Robot.cpp, we are simply trying to call the ahrs constructor within the Robot constructor via
ahrs = new AHRS(SerialPort::kMXP);
Whenever we try to compile, we get the error
invalid new-expression of abstract class type "AHRS"
The code worked perfectly last year, what’s the difference? How can I fix it?
Thanks in advance,
Noah
President and Programmer, 2551
Hi Noah,
Have you updated the navX-MXP C++ RoboRIO libraries to the latest?
There was a change to the WPI Libraries for the 2018 season that required a change to the navX-MXP libraries (a parent class of the AHRS class changed). From the detail you provided, it appears the navX-MXP libraries are out of sync with the WPI Library.
  • scott
Thanks Scott,
This sorted out the original issue, but now we have a general error:
The type 'AHRS' must implement the inherited pure virtual method 'frc::Sendable::InitSendable'
I’m convinced it will sort itself out as it seems to be a WPI issue and we’ve had similar ones that just disappeared in the past, so it doesn’t seem to be a big deal.
Thanks again,
Noah
Hi Noah, can you please let me know which version of WPI Plugins you currently have installed into Eclipse?
Hi Scott,
We have the latest 2018.1.1 Robot C++ Development software installed.
Thanks; I’ll check and see if we can replicate the problem. I’ll get back to you, hopefully by tomorrow. We’ll get it solved.
We’ve updated the navX-MXP for RoboRIO installer; the latest version is 3.0.346. Please install this, rebuild your application and let us know the results.
I was not able to replicate the compile error you reported, so there might still be a configuration problem on the development computer you are using. If you still have problems after running the latest install, please check the path to the navx_frc_cpp library in your build. It’s possible that it does not point to C:\Users<curr_user_name>\wpilib\user\cpp\lib - which is the current location for the navX-MXP for RoboRIO C++ Library.
Thanks, I got it working. It ended up being some combination of reinstalling eclipse, the WPI plugins, the AHRS library, and then wiping and re-pulling from our GitHub. Thanks for the help!
  • Noah
You are welcome - all the best to your team. If you need any further support, you can email us at [email protected] or visit the Kauai Labs support site.
