navX2 Case
We just received a new navX2 for a new robot. I just wanted to make aware that the official case does not work with the v4.2. For comparison, it does with the v4.1. Attached are the two versions side by side: some of the pins are not aligned.
Creating an Enclosure | navX-MXP
Processing: IMG_20241022_084309.jpg…
Unless I’m just blind, the only significant things that appear to be different is the dip switches and USB port, the pins look like they’re basically the same to me… :thinking:
Also, those poor pins, this aught to be tagged #gore or something :joy:
I’d suggest using this case without holes.
We also made a version of that case with a cutout for the mini USB port to use as a secondary source of power.
r/softwaregore maybe? :rofl:
Just tried this one. The cutouts for the pins are at the same location as the first one, which means it doesn’t fit. The pins are off by a few mm.
