Navx2-mxp having weird inaccuracies
Hi, I’m using a navx on a swerve bot and when I go slowly, it stops registering yaw until I stop, when it will then start rapidly decreasing in the opposite direction, throwing everything off. Does anyone know how to fix this? Also it’s “displacement” mode was completely off.
Check your power draw that it’s not resetting your gyro. Also ensure to calibrate your navx for your current altitude.
I will. One of the other navx’s we have has a jumper setting it to 3.5v, should I try that?
That shouldn’t change anything, those are for the logic voltages for your input/output DIO and analog input settings.
What firmware is on the NavX?
The firmware is v3.3
