navX2 MXP Interference
Hey all! We started setting up our final electronics configuration. We are using a steel plate to mount all the electronics onto. However we are a bit skeptical because the steel might cause interference with our navX2. On the other hand, the gyro is being calibrated every startup so we do not think it will be a big issue. Will the steel plate throw off our gyro readings? If so how could we insulate it?
The gyro is accelerometer-based and that won’t be affected by nearby magnetic fields or ferrous materials.
There is a magnetometer on the NavX2 (to measure absolute heading based on magnetic field) but it’s unreliable in FRC circumstances and I don’t know of anyone using that feature.
That said, try to keep high current wires (like motor and battery cables) away from low current signal circuits, just as a general rule, but don’t stress too much about it.
Got it, that’s perfect! Also do you reckon we’ll face any issues with the rest of the electronics such as the Roborio and the PDP?
I don’t think so.
