I always enjoy seeing a neat wiring job in an electrical control panel.
Someone took great care in laying that wire out.
I only wish we all had more time and space to do the same in our robots.
I have seen some very nice wiring jobs this year and in the past. Maybe there will be an award for just wiring someday.
We always try to do a good job…but Time and space is sometimes against us.
Ok… can’t help it… robotics kid and all… Is the picture of that wiring job from a large motor controller? With the large caps, fuses, heat sinked thing (most likely ac triacs)… leads me to think so.
Without seeing a larger picture and more items I cant tell what it is. It appears to be close to either a speed controller or possibly just a motor start controller as the capacitors are hooked to the heat sinked items.
At one point this build season, I took off a quarter of a pound on the bot just cutting off the ends of zipties :eek: … There were so many, I just had to weigh them when I was finished. I wound up re-doing the whole board anyway on a different piece of material, and this time designed it so that I could use less zipties…
I’ll find a picture somewhere of all of those ziptie ends on a scale…
Off topic but, We only use 2 small CIMs with banebots gearboxs and we can push arround other robots, climb up ramps, and manuever better then most teams. We geared it down to a theoretical speed of 7ft/s, so we have plenty of torque and are slow enough to handle easily.
Gone are the days of using only 2 small CIMs to drive your bot around. Now everything has to be a pushing match. It really is scary how you usually need the 2 large CIMs or 4 small CIMs just to be competitive, especially as a defense bot / good offense bot that can’t be pushed around.
That’s not an ac triac. It’s a three phase bridge rectifier. I actually managed to find the part number because the package looked similar to others I’ve seen from the same company. The also color coded for three phase power (Red Blue and Black). The round clynidrical objects below the relays are power resistors and are most likely wire wound. Even the ones with the bands on them are beefier than usual. It almost looks like part of a motor testing bench from my perspective. I’ll go into more detail later about the how the setup works though later.
