Hi everyone, rookie team with little coding experience. Trying to set limits of our arm using the encoder on my neos. my high limit is -.7167 and resting position is 0. The encoder works, just not able to take its value and compare it to my high limit. For example: armEncoder > targetPosition, issue is that it can’t compare a relative encoder value with a double (arm encoder being the relativeEncoder and target position being a double value i made). Is there any way to convert the encoder reading to a double or make my target position double into the same datatype as the other one. I thought the encoder was supposed to return a double, but it doesn’t seem to. Ill include all my code down below. Sorry if its messy Thanks in advance! Team 9474
package frc.robot;
import edu.wpi.first.wpilibj.XboxController;
import com.revrobotics.RelativeEncoder;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkLowLevel.MotorType;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import java.math.BigDecimal;
- This function is run when the robot is first started up and should be used for any
- initialization code.
//Motor initilization!!
//public CANSparkBase(int, device6 CANSparkLowLevel, )
private CANSparkMax leftMotor2 = new CANSparkMax(4, MotorType.kBrushed);
private CANSparkMax rightMotor1 = new CANSparkMax(3, MotorType.kBrushed);
private CANSparkMax leftMotor1 = new CANSparkMax(2, MotorType.kBrushed);
private CANSparkMax rightMotor2 = new CANSparkMax(1, MotorType.kBrushed);
private CANSparkMax intakeMotor = new CANSparkMax(5, MotorType.kBrushless);
private CANSparkMax armMotor = new CANSparkMax(6, MotorType.kBrushless);
private RelativeEncoder armEncoder;
private DifferentialDrive drive;
private DifferentialDrive drive2;
//These will be used later for my whack acceleration thing!
public final double gainspeed = 0.5;
public final double gainturn = 0.5;
public double multiplier = 0;
public double multiplier2 = 0;
public double timer = 0;
public double targetPosition = 5.00;
public double restingPosition = 0.00;
XboxController controller = new XboxController(0);
@Override
public void robotInit() {
drive = new DifferentialDrive(leftMotor1, rightMotor1);
drive2 = new DifferentialDrive(leftMotor2, rightMotor2);
@Override
public void robotPeriodic() {}
@Override
@Override
@Override
public void teleopInit() {
@Override
double f_b = controller.getRawAxis(1);
double l_r = controller.getRawAxis(4);
// Drive the robot
drive.arcadeDrive(-l_r, f_b);
drive2.arcadeDrive(-l_r, -f_b);
if(controller.getLeftTriggerAxis() > .5){
intakeMotor.set(.28);}
else {intakeMotor.set(0);
armEncoder = armMotor.getEncoder();
SmartDashboard.putNumber(“Encoder Position”, armEncoder.getPosition());
if(controller.getRightTriggerAxis() >.8){
armMotor.set(.2);
}else if(armEncoder > targetPosition){
else{
armMotor.set(0);
if(controller.getAButton() == true){
armMotor.set(-0.2);
}else{
armMotor.set(0);
@Override
public void disabledInit() {}
@Override
public void disabledPeriodic() {}
@Override
public void testInit() {}
@Override
public void testPeriodic() {}
@Override
public void simulationInit() {}
@Override
public void simulationPeriodic() {}
