Need Help w/ pnuematics programming idea!!!
I’m using EasyC.
I was thinking of controlling the soleniods in the following manner (and this is psuedocode)
Setup info: I have a global button_counter(1) integer that keeps track of how many times a button has been pressed on the joystick, and I have a relay, and I have a button(1) variable that holds input from one of the joystick buttons. The example uses ‘button1’ and ‘button_counter1’ but could work for buttons 1 through for 4 to control seperate soleniods or relay attachments.
If button(1) is pressed
button_counter1 ++
// turn on relay in one positive direction
if button_count == 0
{  while (button not pressed again)
    set relay1(1,0)
else if button_count == 1
    { set relay1(0,0) }
 else if button_count == 2
   { set relay1(0,1)  }
 else { set relay1(0,0); button_count = 0;}
 end if
end if
The purpose being to be able to have the flow controlled for each soleniod by only 1 button being pressed. I don’t have access to the robot to know exactly how they work. I’m doing this code from remote location and need help as soon as possible. Will this work, if not why not? Please PM me if you have a suggestion.
Also, how do I capture the event of a button press?
I don’t know how to set a listener for an OI digital input that could then be the codition for the original if
