Need help with Axis 206 Power Adapter
i need the Network Adapter 2-Lead PN# SA106A-0512-6 and i dont know where to find it, nothing on the search engines and does anyone know if i can replace it with something else from radio shack, i dont have the specs that are written on the adapter because i dont have it.
thank you
Output specs are 5.1v, 2amps
center positive on the connector, but I can’t remember the barrel type.
The two adaptors in the KOP weren’t enough? :slight_smile:
http://www.axis.com/products/cam_acc/powersupp/index.htm
Mains adaptor PS-H part # 5500-331
Should be able to find a close match at Radio Shack.
Goggle it and you get a bunch of hits like this ($39): http://www.moonblinkwifi.com/pd-power-supply-psh--5500331.cfm
