Need help with FRC Radio Component
We are currently working on the wireless connection and all the state lights on our radio bridge work as intended. However, no wifi connection shows up on our laptops. We have flashed the firmware using the FRC Radio Configuration Utility, and when we try to configure the bridge it always gets an error at the last moment, saying something like cannot reconnect and suggest us to check the connection or power cycle the bridge, but none of these suggestions solves the problem.
We wanna know if this is the problem with the configuration. If yes, how should we configure it successfully?
Any answer is appreciated, plz help.
When using the radio configuration are you disabling all the network adapters on your laptop? On another thread someone used a network switch as well.
