Need Maxplanitary gearbox
Team 3216 needs one maxplanitary basekit for our climbers. We will pay 50 bucks for one and shipping. Dm me if interested! Thanks you!
just send offers and we will se if we can match it!
Guys please I beg
If you get desperate you can get the CIM Sport from andymark
I want to say part of receiving a response was due to how your initial wording was. I will see if we can spare one at practice tonight.
Can a versaplanetary work?
We will see but with the climber setup we have the short shaft isn’t long enough
Thanks you.
If nothing else; with the versplanetary, the shaft should be tapped for 1/4-20. You can take another shaft and tap that 1/4-20, screw a 1" bolt into the VP shaft and cut off the head to make a double sided bolt, allowing you to screw the other shaft onto it. Put a nut on the bolt before you cut the head off so you can reform the threads.
Versa also has a female hex output adapter but its kinda sketchy and you have to space the gearbox away depending on the application
Ya we tryed it and we are worried with our spacing of the climbers that the shaft length will be a huge issue
Would recommend not using the VP female hex adapter, it is susceptible to shock loads and we broke one a few years ago.
Can you use a standard hex output versaplanetary turning gears, chain, or a MAX 90 Degree gearbox?
Another consideration is to use a long hex coupler (QTY 2 - Half Inch Hex Coupler) and link the versa hex output shaft with the shaft length you need. That’s far stronger than the female hex ouptut adapter, probably not as good as a MAX 90 degree.
I’d sell you a base kit if I had one to sell, we’ve had multiple teams asking about them.
Good luck!
We barely use versa planetary stuff anymore. I was just stating that it did exist but is a pain
We have one for you dm me the address
The CIM Sport also has a Female Output Shaft option as well as longer standard output shafts if needed.
