OK, so I have this final project for my class in school and I have some clue but I thought I’d let all my fellow FIRSTers weigh in on it. Here’s the details:
I have to make a machine that will move a marble 10 inches in any direction, and then return it to its starting position.
Rules:
Can only touch the machine once to start it.
Use a battery supply.
Maximum of 2 feet by 2 feet.
Place it on a level tabletop.
Include motor/gears, relay, switch,conductors and Incorporate 2 Different simple machines in the machine;
-Lever
-Inclined Plane
-Wedge
-Gear
-Pulley
-Belt Drive or
-Wheel and Axle
-Cant touch the marble to start it
If you have any ideas, suggestions/comments, reply at will.
Ok so make a see-saw type contraption, 10" long and when you start it the see saw will send the marble from one end to the other and then back all with one little motor.
So does that mean the natural movement of a see saw would not be acceptable?? Does something have to touch the marble to push it? Or can it just be inclined to roll???
