For reference, I’m doing this on the new 2023 version of the WPI VS Code. I have no errors at least syntactically. However, every time I run this super bare-bones code it always fails to build. Is there a new way to create the neo encoders in java?
also here are my imports
package frc.robot.subsystems;
import com.revrobotics.CANSparkMax;
import com.revrobotics.RelativeEncoder;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
import edu.wpi.first.wpilibj.CounterBase.EncodingType;
import edu.wpi.first.wpilibj2.command.CommandBase;
import edu.wpi.first.wpilibj2.command.SubsystemBase;
import frc.robot.Constants;
Error message
Task :compileJava FAILED
C:\Users\clark\OneDrive\Desktop\Command\COMMAND\src\main\java\frc\robot\subsystems\DriveTank.java:23: error: cannot access SpeedController
private final RelativeEncoder lefEncoder = leftFrontMotor.getEncoder();
class file for edu.wpi.first.wpilibj.SpeedController not found
1 error
Compilation Error!
GradleRIO detected this build failed due to a Compile Error (compileJava).
