Week 2 (1/13 to 1/20)
Assembly
Training
We conducted training for new members (Rotations):
- Motor testing
- Used phoenix tuner and driver’s station
- Recorded motor data in a spreadsheet and labeled motors
- Comp maintenance
- Pneumatics
- How to use the manual test bench
- Layout and components of prototype bot pneumatics
- Soldering
- Chain Tensioning
- Practicing chain tensioning by using wrenches to tie and loosen snail gears
Claw
Once the assembly of the double piston claw was done, we attached it to the prototype bot.
Image of the completed claw assembly
We fixed a claw prototype’s cone compression.
Demo of claw holding cone
We tested a claw prototype
- Set up pneumatic test bench and tested the two-piston claw design. It was successful for both the cone and the cube.
We finished the assembly of the claw prototype. Upon completion, it was tested and successfully picked up and scored a cone on the node about 4 times until the wood snapped while testing.
Broken wood on claw prototype
Arm
Installed the piston on arm
Piston attatched to claw prototype
Elevator
We also worked on the elevator prototype:
- Worked with CAD in assembly of the elevator
- Took inventory for elevator parts
- Riveted U shape
The start of our elevator prototype
Cone Runner
We worked on the assembly of the cone runner intake prototype.
- Once assembled, we tested it.
Assembled cone runner intake prototype
Video of the intake working: 2fec204ef34c4fb4be7b5f9c99bf19b9.MOV - Google Drive
Field Elements
We finished assembling the end cone ramp.
Connected the cube shelf divider beam to cone ramp horizontal beam using wood screws and spacer plywood
Image of the completed Cone Ramp.
Made a substation height simulator (Double Substation Stand)
New double substation stand
Robot Repairs/Maintenance
We did several repairs on our prototype bots such as:
- Fixed CAN on prototype bot
- Fixed gearboxes on prototype bot
- We finished attaching handles onto our swerve bot.
Handles on Swerve
We fixed a Pneumatic Leak in our Prototype Bot:
We found slanted tubing, so we cut a new tube and reconnected it
Robot Cart
We continued brainstorming and designing a new robot cart. We completed the following:
After the brainstorming on Friday, we made the 1st iteration design and reviewed those designs with our advisor
CAD design of new robot cart
We continued to work on Robot Cart.
- Got feedback from advisor
- Created a 2nd iteration
- Started Bill of Materials (BOM)
Two possible designs for the robot cart
Driver Station
We began work on a new driver station.
- Assembled the base of the driver station.
- Used the bandsaw to cut bars for the base and polycarb.
Finished driver station base
Other
We repaired the Wooden Dolley our team uses to push around large materials.
- Replace broken plywood
- Stapled fabric using staple gun
Fixed Wooden Dolley
We also assembled versaplanetary gearboxes for our prototype bot.
We started working on our new robot cart and driver’s station.
- brainstorming updated designs
- design constraints
- additional features
We recorded inventory for the following components:
Did basic battery maintenance:
- Battery Leads: take off and replace battery leads. Use heat gun to secure heatshrink.
- Tested 2 batteries with a computerized battery analyzer
Made changes to encoder connection (NEOs):
- Spliced 24AWG onto 28AWG onto neo motor encoder wires
We Disassembled telescope climb to get more parts needed for other claw prototypes:
We recorded inventory for versaplanetary gearboxes.
Some assembly members had Manufacturing Training on:
- Work offsets
- Helping MFG with parts list
- Facing, probing
We performed the following electrical work:
- Prepared CANcoders for 2nd swerve
Completed encoder preparation
We helped the ADMIN sub team with the following:
- Created FRC sponsors Stickers
- Started design for sponsorship panels
Image of our sponsor panel layout
CAD
Telescope Arm
First cad of two stage telescope arm. Each tube is 27 inches long. Received feedback. Need to find a way to move the arm. Thinking of attaching motor to elevator carriage.
Screenshot of arm CAD
Elevator
We finished updating the elevator. Some of the updates included making the bars into 29 inches to make it easier for manufacturing. We created drawings of all the parts, and created a BOM that we must order to make the elevator.
Screenshot of elevator CAD
Rotational Claw
We then tested the rotational claw with the pneumatic piston test bench and had 100% success rate out of 10 trials with cone and cube.
Screenshot of the claw cad.
Buddy Climb
We started on the first buddy climber prototype design using pieces of plywood. Functionalities wise we wanted the swerve drive base to drive on to the structure and the T shape to hook underneath the swerve drive base wheels. We chose a T shape to accommodate the locations of the wheels of varying drive bases.
CAD and prototype of buddy climb
Polycarbonate was also added to the buddy climber prototype for stability and better testing results.
2nd itteration of buddy climb
Video: IMG_0267.MOV - Google Drive
Cone Runner
We wanted to focus on ground intake and created a cone runner design and a single angular ground intake design.
CAD model of cone runner design
Swerve Bumpers
After testing dimensions with a current swerve drive base docking and engaging we completed the swerve bumper design with technical drawings from those dimensions. We wanted to make the process of taking off bumpers and putting them back on as easy as possible. We went with a pin design with 4 c-channel mounts with two on opposite sides.
Screenshots of the drawings for our swerve bumpers
This swerve drive was previously used during the off season of 2022-2023 and now with season we had to make a few changes with the handlebar placement and crossbar placement for the future design this is to model potential configurations but is not final.
Then we created a structure for the cone runner to mount on that is 4 inches tall and 11 inches wide.
West Coast Bumpers
Moving on to west coast drive base bumpers, we completed the first design and started on technical drawings. Again, using c-channel for a pin attachment like the swerve bumpers design. Changed the c-channel placement and the wood lengths.
CAD model of West Coast bumpers
Manufacturing
TM-1 Cleaning
The manufacturing subteam set up a 3D printer with TPU filament and another with Nylon X to test the usability of the various materials. We printed a test belt with the TPU, which proved to be successful. We also reorganized and lowered our stock rack so that we could add more shelves and create a more efficient storage area for manufacturing. Furthermore, the side guards on the TM-1 were removed in preparation for the elevator bar. The TM-1 vises and work surface, as well as the side guards, were vacuumed and cleaned with oil.
*A close-up of the tidied bare TM-1 work surface. *
A full shot of the TM-1 with its guard railing removed.
A selfie shot of the people who busted their butts and worked through approx. 10 machine cloths to get this baby nice and shiny.
*A full shot of our cleaned guard railing with its screws and washers (for connection to the TM-1) taped on to ease reattachment + the tips of my feet (how scandalous). *
Gussets & Bars
At the beginning of the day, half of the manufacturing subteam helped disassemble the hangar from last year’s game while the other half reviewed the completed elevator CAD drawings. After some modifications in the gussets, the drawings were approved for manufacturing. The parts were first divided into which CNC mills they would be manufactured on and then divided into groups regarding their plate thickness (gussets). We completed all of the bar CAMs and are almost done with the gusset CAMs. The stock was also cut in preparation for facing (bar length + .25 in).
Picture of the completed CAM for the .125 gussets
On January 16th, the manufacturing subteam began facing the remaining bar stock and finalizing the CAM for the gussets. However, there was some miscommunication regarding the thickness of the gusset plates, so the gussets were reCAMed. However, the original .0625in plate gussets (P407 – qt8, P408 – qt4, P414 – qt2) were completed by the end of the meeting and bandsawed off the plate. 4 bars were completed by the end of the meeting (P401 – qt2, P406 – qt1, P409 – qt1).
Completed plate with corner gussets - P407, bot motor gusset - P408, and backrest gusset - P414
Completed bars (base up bar - P401 , carriage beam - P406 , bot rail – P409)
On Thursday, all the bars for elevator (except for top support rail) were completed and the mini mill was set up to run the remaining .0625 parts.
During a worktime of approximately 90 minutes, manufacturing sanded and buffered the previously manufactured gussets. They were then chamfered on both sides, but the team then found that the reaming program for the gussets were too shallow and did not allow for some holes to fit a rivet. To ensure that all holes could be riveted, we deburred the faulty holes. However, we discovered our error in the CAM when the bottom height of the reamer was due to the program not acknowledging the reamer tip in “drill tip through”. Thus, in future parts, we have fixed this issue and the reamers fit.
Our completed sanded, buffered, and chamfered gussets.
One sheet of .0625 gussets were manufactured with the intent to be doubled to .125 gussets (as we had run out of 1/8 alum sheets). Members learned how to bandsaw round edges of the gussets through relief cuts. However, due to the change in CAD design, manufacturing gussets was put on hold. Instead, we CAMed a program to drill shoulder screw holes into new 1/16 sheets of aluminum so that they could be manufactured on our tooling plate.
MFG members hard at work
Gussets for another swerve drive were CAMed and dry run on the mini mills, but not manufactured due to a shortened meeting time.
Organization of Stock Rack
Reorganized stock rack
Programming
Vision Group
This week, we learned that there are two methods of determining the robot’s distance from the april tags using the Limelight. The first method uses the angle and the height of the camera along with the angle and height of the april tag to determine the distance from the camera to the target. It also uses the angle from the Limelight to the target which is the value that is changed to help determine the distance between the Limelight and april tag. However, if the numbers were slightly off, then the distance would be changed exponentially. That is why we decided to go with the second method that uses the area of the Limelight which the target takes up. To do so, we had to find an equation to determine how the area of the target relates to the distance between the Limelight and the april tag. We tested the turning using the pitch received from the Limelight, and it was successful
Auto Group
First, we continued testing the drive and claw functionalities of the prototype bot. For the sides of the drive base that had an unused motor, the motor current ramped up to around 178 amps. The removal of the motor resulted in the motor current ramping up to only around 30-40 amps, which is a safe amount. Next, we tested autos that drove straight and faced a certain angle using a NavX, but they need further PID tuning. We have also tested several buddy climb iterations. There were some successful trials; however, the swerve drivetrain was unable to stay on the buddy climb for most trials.
Swerve Group
This week, we worked on adding smaller features to our codebase.
First, we transferred some of the swerve commands we had written, such as turn to angle using the gyroscope and charge station balancing, to be compatible with a west coast drivetrain, as at this point, we were not sure which drivebase we would be committing to.
After that, we worked on adding logging to the robot, first testing using the WPILib DataLog framework on a testbench, and then writing code to implement it into our subsystems. We hope that this will solve some of our slowdown issues from last year, when we used BadLog for logging, as DataLog does I/O operations on a separate thread, which should reduce slowdown.
public static void init() {
// Old logging code
createTopic("LeftMaster" + "/Voltage", () -> robotContainer.drivetrain.leftMaster.getMotorOutputVoltage());
createTopic("RightMaster" + "/Voltage", () -> robotContainer.drivetrain.leftMaster.getMotorOutputVoltage());
createTopic("RightFollower" + "/Voltage", () -> robotContainer.drivetrain.rightSlave.getMotorOutputVoltage());
createTopic("LeftFollower" + "/Voltage", () -> robotContainer.drivetrain.leftSlave.getMotorOutputVoltage());
createTopic("LeftMaster" + "/Current", () -> robotContainer.drivetrain.leftMaster.getMotorOutputVoltage());
createTopic("RightMaster" + "/Current", () -> robotContainer.drivetrain.leftMaster.getMotorOutputVoltage());
createTopic("RightFollower" + "/Current", () -> robotContainer.drivetrain.rightSlave.getMotorOutputVoltage());
createTopic("LeftFollower" + "/Current", () -> robotContainer.drivetrain.leftSlave.getMotorOutputVoltage());
@Override
public void robotInit() {
// New logging code (logs everything from networktables)
DataLogManager.start("/lvuser/logs/");
DataLogManager.logNetworkTables(true);
