Netbeans can't load DefaultCodeProject
We are starting on Java with Netbeans from scratch this year, and are having problems getting going. When we attempt to load the DefaultCodeProject into a new project, in step 2 it goes to the Target Location screen, which is not described in the manual. I suspect that the DefaultCodeProject is either missing or a link to it is bad. Anyone see this before?
I have had the same issue, but only since the January 21 update. If you need it, I have the code for the Default Program.
Here:
/* Copyright © FIRST 2008. All Rights Reserved. /
Open Source Software - may be modified and shared by FRC teams. The code /
must be accompanied by the FIRST BSD license file in the root directory of /
the project. /
package edu.wpi.first.wpilibj.defaultCode;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
  • This “BuiltinDefaultCode” provides the “default code” functionality as used
  • in the “Benchtop Test.”
  • The BuiltinDefaultCode extends the IterativeRobot base class to provide the
  • “default code” functionality to confirm the operation and usage of the core
  • control system components, as used in the “Benchtop Test” described in
  • Chapter 2 of the 2009 FRC Control System Manual.
  • This program provides features in the Disabled, Autonomous, and Teleop modes
  • as described in the benchtop test directions, including “once-a-second”
  • debugging printouts when disabled, a “KITT light show” on the solenoid lights
  • when in autonomous, and elementary driving capabilities and “button mapping”
  • of joysticks when teleoperated. This demonstration program also shows the use
  • of the user watchdog timer.
  • This demonstration is not intended to serve as a “starting template” for
  • development of robot code for a team, as there are better templates and
  • examples created specifically for that purpose. However, teams may find the
  • techniques used in this program to be interesting possibilities for use in
  • their own robot code.
  • The details of the behavior provided by this demonstration are summarized
  • below:
  • Disabled Mode: - Once per second, print (on the console) the number of
  • seconds the robot has been disabled.
  • Autonomous Mode: - Flash the solenoid lights like KITT in Knight Rider -
  • Example code (commented out by default) to drive forward at half-speed for 2
  • seconds
  • Teleop Mode: - Select between two different drive options depending upon
  • Z-location of Joystick1 - When “Z-Up” (on Joystick1) provide “arcade drive”
  • on Joystick1 - When “Z-Down” (on Joystick1) provide “tank drive” on Joystick1
  • and Joystick2 - Use Joystick buttons (on Joystick1 or Joystick2) to display
  • the button number in binary on the solenoid LEDs (Note that this feature can
  • be used to easily “map out” the buttons on a Joystick. Note also that if
  • multiple buttons are pressed simultaneously, a “15” is displayed on the
  • solenoid LEDs to indicate that multiple buttons are pressed.)
  • This code assumes the following connections: - Driver Station: - USB 1 - The
  • “right” joystick. Used for either “arcade drive” or “right” stick for tank
  • drive - USB 2 - The “left” joystick. Used as the “left” stick for tank drive
    • Robot: - Digital Sidecar 1: - PWM 1/3 - Connected to “left” drive motor(s)
    • PWM 2/4 - Connected to “right” drive motor(s)
  • The VM is configured to automatically run this class, and to call the
  • functions corresponding to each mode, as described in the IterativeRobot
  • documentation. If you change the name of this class or the package after
  • creating this project, you must also update the manifest file in the resource
  • directory.
    public class DefaultRobot extends IterativeRobot {
    // Declare variable for the robot drive system
    RobotDrive m_robotDrive; // robot will use PWM 1-4 for drive motors
    int m_dsPacketsReceivedInCurrentSecond; // keep track of the ds packets received in the current second
    // Declare variables for the two joysticks being used
    Joystick m_rightStick; // joystick 1 (arcade stick or right tank stick)
    Joystick m_leftStick; // joystick 2 (tank left stick)
    static final int NUM_JOYSTICK_BUTTONS = 16;
    boolean] m_rightStickButtonState = new boolean(NUM_JOYSTICK_BUTTONS + 1)];
    boolean] m_leftStickButtonState = new boolean(NUM_JOYSTICK_BUTTONS + 1)];
    // Declare variables for each of the eight solenoid outputs
    static final int NUM_SOLENOIDS = 8;
    Solenoid] m_solenoids = new Solenoid[NUM_SOLENOIDS];
    // drive mode selection
    static final int UNINITIALIZED_DRIVE = 0;
    static final int ARCADE_DRIVE = 1;
    static final int TANK_DRIVE = 2;
    int m_driveMode;
    // Local variables to count the number of periodic loops performed
    int m_autoPeriodicLoops;
    int m_disabledPeriodicLoops;
    int m_telePeriodicLoops;
    • Constructor for this “BuiltinDefaultCode” Class.
    • The constructor creates all of the objects used for the different inputs
    • and outputs of the robot. Essentially, the constructor defines the
    • input/output mapping for the robot, providing named objects for each of
    • the robot interfaces.
      public DefaultRobot() {
      System.out.println("BuiltinDefaultCode Constructor Started
      // Create a robot using standard right/left robot drive on PWMS 1, 2, 3, and #4
      m_robotDrive = new RobotDrive(1, 2);
      m_dsPacketsReceivedInCurrentSecond = 0;
      // Define joysticks being used at USB port #1 and USB port #2 on the Drivers Station
      m_rightStick = new Joystick(1);
      m_leftStick = new Joystick(2);
      // Iterate over all the buttons on each joystick, setting state to false for each
      int buttonNum = 1; // start counting buttons at button 1
      for (buttonNum = 1; buttonNum <= NUM_JOYSTICK_BUTTONS; buttonNum++) {
      m_rightStickButtonState[buttonNum] = false;
      m_leftStickButtonState[buttonNum] = false;
      // Iterate over all the solenoids on the robot, constructing each in turn
      int solenoidNum = 1; // start counting solenoids at solenoid 1
      for (solenoidNum = 0; solenoidNum < NUM_SOLENOIDS; solenoidNum++) {
      m_solenoids[solenoidNum] = new Solenoid(solenoidNum + 1);
      // Set drive mode to uninitialized
      m_driveMode = UNINITIALIZED_DRIVE;
      // Initialize counters to record the number of loops completed in autonomous and teleop modes
      m_autoPeriodicLoops = 0;
      m_disabledPeriodicLoops = 0;
      m_telePeriodicLoops = 0;
      System.out.println("BuiltinDefaultCode Constructor Completed
    • ******************************** Init Routines ************************************
      public void robotInit() {
      // Actions which would be performed once (and only once) upon initialization of the
      // robot would be put here.
      System.out.println("RobotInit() completed.
    public void disabledInit() {
    m_disabledPeriodicLoops = 0; // Reset the loop counter for disabled mode
    ClearSolenoidLEDsKITT();
    startSec = (int) (Timer.getUsClock() / 1000000.0);
    printSec = startSec + 1;
    public void autonomousInit() {
    m_autoPeriodicLoops = 0; // Reset the loop counter for autonomous mode
    public void teleopInit() {
    m_telePeriodicLoops = 0; // Reset the loop counter for teleop mode
    m_dsPacketsReceivedInCurrentSecond = 0; // Reset the number of dsPackets in current second
    m_driveMode = UNINITIALIZED_DRIVE; // Set drive mode to uninitialized
    • ******************************** Periodic Routines ************************************
      static int printSec;
      static int startSec;
    public void disabledPeriodic() {
    // feed the user watchdog at every period when disabled
    Watchdog.getInstance().feed();
     // increment the number of disabled periodic loops completed
     m_disabledPeriodicLoops++;
     // while disabled, printout the duration of current disabled mode in seconds
     if ((Timer.getUsClock() / 1000000.0) &gt; printSec) {
         System.out.println("Disabled seconds: " + (printSec - startSec));
         printSec++;
    public void autonomousPeriodic() {
    // feed the user watchdog at every period when in autonomous
     m_autoPeriodicLoops++;
     // generate KITT-style LED display on the solenoids
     SolenoidLEDsKITT(m_autoPeriodicLoops);
      * the below code (if uncommented) would drive the robot forward at half
      * speed for two seconds. This code is provided as an example of how to
      * drive the robot in autonomous mode, but is not enabled in the default
      * code in order to prevent an unsuspecting team from having their robot
      * drive autonomously!
     //below code commented out for safety
     if (m_autoPeriodicLoops == 1) {
         // When on the first periodic loop in autonomous mode, start driving forwards at half speed
         m_robotDrive.drive(1.0, 0.0);			// drive forwards at half speed
     if (m_autoPeriodicLoops == (2 * GetLoopsPerSec())) {
         // After 2 seconds, stop the robot
         m_robotDrive.drive(0.0, 0.0);			// stop robot
    public void teleopPeriodic() {
     // increment the number of teleop periodic loops completed
     m_telePeriodicLoops++;
      * Code placed in here will be called only when a new packet of
      * information has been received by the Driver Station. Any code which
      * needs new information from the DS should go in here
     m_dsPacketsReceivedInCurrentSecond++;					// increment DS packets received
     // put Driver Station-dependent code here
     // Demonstrate the use of the Joystick buttons
     Solenoid] firstGroup = new Solenoid[4];
     Solenoid] secondGroup = new Solenoid[4];
     for (int i = 0; i &lt; 4; i++) {
         firstGroup* = m_solenoids*;
         secondGroup* = m_solenoids*;
     DemonstrateJoystickButtons(m_rightStick, m_rightStickButtonState, "Right Stick", firstGroup);
     DemonstrateJoystickButtons(m_leftStick, m_leftStickButtonState, "Left Stick ", secondGroup);
     // determine if tank or arcade mode, based upon position of "Z" wheel on kit joystick
     if (m_rightStick.getZ() &lt;= 0) {    // Logitech Attack3 has z-polarity reversed; up is negative
         // use arcade drive
         m_robotDrive.arcadeDrive(m_rightStick, false);			// drive with arcade style (use right stick)
         if (m_driveMode != ARCADE_DRIVE) {
             // if newly entered arcade drive, print out a message
             System.out.println("Arcade Drive
m_driveMode = ARCADE_DRIVE;
} else {
// use tank drive
m_robotDrive.tankDrive(m_leftStick, m_rightStick); // drive with tank style
if (m_driveMode != TANK_DRIVE) {
// if newly entered tank drive, print out a message
System.out.println("Tank Drive
m_driveMode = TANK_DRIVE;
 * Clear KITT-style LED display on the solenoids
 * Clear the solenoid LEDs used for a KITT-style LED display.
public void ClearSolenoidLEDsKITT() {
    // Iterate over all the solenoids on the robot, clearing each in turn
    for (solenoidNum = 0; solenoidNum &lt; NUM_SOLENOIDS; solenoidNum++) {
        m_solenoids[solenoidNum].set(false);
 * Generate KITT-style LED display on the solenoids
 * This method expects to be called during each periodic loop, with the
 * argument being the loop number for the current loop.
 * The goal here is to generate a KITT-style LED display. (See
 * http://en.wikipedia.org/wiki/KITT ) However, since the solenoid module
 * has two scan bars, we can have ours go in opposite directions! The scan
 * bar is written to have a period of one second with six different
 * positions.
public void SolenoidLEDsKITT(int numloops) {
    final int NUM_KITT_POSITIONS = 6;
    int numloop_within_second = numloops % GetLoopsPerSec();
    // note that the array index values below are zero-based, but solonoid numbers are one based.
    if (numloop_within_second == 0) {
        // position 1; solenoids 1 and 8 on
        m_solenoids[0].set(true);
        m_solenoids[7].set(true);
        m_solenoids[1].set(false);
        m_solenoids[6].set(false);
    } else if (numloop_within_second == (GetLoopsPerSec() / NUM_KITT_POSITIONS)) {
        // position 2; solenoids 2 and 7 on
        m_solenoids[1].set(true);
        m_solenoids[6].set(true);
        m_solenoids[0].set(false);
        m_solenoids[7].set(false);
    } else if (numloop_within_second == (GetLoopsPerSec() * 2 / NUM_KITT_POSITIONS)) {
        // position 3; solenoids 3 and 6 on
        m_solenoids[2].set(true);
        m_solenoids[5].set(true);
    } else if (numloop_within_second == (GetLoopsPerSec() * 3 / NUM_KITT_POSITIONS)) {
        // position 4; solenoids 4 and 5 on
        m_solenoids[3].set(true);
        m_solenoids[4].set(true);
        m_solenoids[2].set(false);
        m_solenoids[5].set(false);
    } else if (numloop_within_second == (GetLoopsPerSec() * 4 / NUM_KITT_POSITIONS)) {
        // position 5; solenoids 3 and 6 on
        m_solenoids[3].set(false);
        m_solenoids[4].set(false);
    } else if (numloop_within_second == (GetLoopsPerSec() * 5 / NUM_KITT_POSITIONS)) {
        // position 6; solenoids 2 and 7 on
int GetLoopsPerSec() {
    return 20;
 * Demonstrate handling of joystick buttons
 * This method expects to be called during each periodic loop, providing the
 * following capabilities: - Print out a message when a button is initially
 * pressed - Solenoid LEDs light up according to joystick buttons: - When no
 * buttons pressed, clear the solenoid LEDs - When only one button is
 * pressed, show the button number (in binary) via the solenoid LEDs - When
 * more than one button is pressed, show "15" (in binary) via the solenoid
 * LEDs
public void DemonstrateJoystickButtons(Joystick currStick,
        boolean] buttonPreviouslyPressed,
        String stickString,
        Solenoid solenoids]) {
    boolean outputGenerated = false;		// flag for whether or not output is generated for a button
    int numOfButtonPressed = 0;		// 0 if no buttons pressed, -1 if multiple buttons pressed
     * Iterate over all the buttons on the joystick, checking to see if each
     * is pressed If a button is pressed, check to see if it is newly
     * pressed; if so, print out a message on the console
    for (buttonNum = 1; buttonNum &lt;= NUM_JOYSTICK_BUTTONS; buttonNum++) {
        if (currStick.getRawButton(buttonNum)) {
            // the current button is pressed, now act accordingly...
            if (!buttonPreviouslyPressed[buttonNum]) {
                // button newly pressed; print out a message
                if (!outputGenerated) {
                    // print out a heading if no other button pressed this cycle
                    outputGenerated = true;
                    System.out.println("button pressed:" + stickString);
                System.out.println(" " + buttonNum);
            // remember that this button is pressed for the next iteration
            buttonPreviouslyPressed[buttonNum] = true;
            // set numOfButtonPressed appropriately
            if (numOfButtonPressed == 0) {
                // no button pressed yet this time through, set the number correctly
                numOfButtonPressed = buttonNum;
            } else {
                // another button (or buttons) must have already been pressed, set appropriately
                numOfButtonPressed = -1;
        } else {
            buttonPreviouslyPressed[buttonNum] = false;
    // after iterating through all the buttons, add a newline to output if needed
    if (outputGenerated) {
    if (numOfButtonPressed == -1) {
        // multiple buttons were pressed, display as if button 15 was pressed
        DisplayBinaryNumberOnSolenoidLEDs(15, solenoids);
    } else {
        // display the number of the button pressed on the solenoids;
        // note that if no button was pressed (0), the solenoid display will be cleared (set to 0)
        DisplayBinaryNumberOnSolenoidLEDs(numOfButtonPressed, solenoids);
 * Display a given four-bit value in binary on the given solenoid LEDs
void DisplayBinaryNumberOnSolenoidLEDs(int displayNumber, Solenoid] solenoids) {
    if (displayNumber &gt; 15) {
        // if the number to display is larger than can be displayed in 4 LEDs, display 0 instead
        displayNumber = 0;
    solenoids[3].set((displayNumber & 1) != 0);
    solenoids[2].set((displayNumber & 2) != 0);
    solenoids[1].set((displayNumber & 4) != 0);
    solenoids[0].set((displayNumber & 8) != 0);
Hope this helps!****
