Network tables
Has anyone done much with the new update to network tables?
I’m trying to get the the robot to connect to a custom dashboard using jframes and network tables. Anyone know how i should use network tables to do this?
Check out this post from the 2014 documentation.
http://wpilib.screenstepslive.com/s/3120/m/7912/l/80205-writing-a-simple-networktables-program-in-c-and-java-with-a-java-client-pc-side#!prettyPhoto
I think it will still work. You’ll need to create a desktop java program and include the NetworkTables.jar in your project from the <user>/wpilib/java/currrent/lib folder. Then just try that example. I’ll give it a try tomorrow with a robot to verify that it works, then move that page into the 2015 documentation.
Be sure to add the library to the Project Properties, Java build path, libraries project settings.
I was able to get a desktop program to connect to the smart dashboard using network tables so I am pretty sure it still works.
Thank you so much!
This year is my first with working with network tables, so I hope this works!
To add on to this, does anyone know of getting the camera images onto the custom dashvboard? I need to get both the usb and axis images.
find the ip addresses of the cameras using the webdashboard for the roborio located at “roborio-####.local” where #### is your team number, or something similar to it.
