As mentor for a team that makes heavy use of the command-based framework (and one who also does not particularly care for the “standard” implementation thereof), I guess I’ll respond.
For starters, I agree that the template is not very good. It doesn’t do a good job of outlining the underlying design of the framework, nor does it give any indication that there is a fair amount of flexibility in its use. The documentation provided by ScreenSteps to match the template is inadequate, and suffers from many of the same problems. However, I think many of your specific criticisms are off-base, or at the very least not adequately articulated.
The lack of “test” mode being set up for you is really, really minor. Our team has never used the supported test mode for testing anyway, because it’s rather clunky and we’ve always found it easier to just modify our ordinary teleop or autonomous code. This isn’t a real strike against the testability of command-based, and it certainly doesn’t indicate that “the author didn’t even consider testing to be an important element.”
That subsystems are declared as global variables is a valid gripe in certain contexts, but not really for the reasons you state. If you don’t intend to re-use any of your robot code, you’re not really going to get burned by having global (or singleton, if you want to be a *bit *fancier) subsystems.
Where the subsystems-as-global-variables design really hamstrings you is in code re-use; commands written in the “standard” command-based style are rigidly-coupled to the subsystems they use, and thus can rarely be used again on future robots. The best way to address this is to inject your subsystems into your commands, and write your commands so that your subsystems are hidden behind interfaces - but for a team that’s just starting out (which is the situation in which one is most-likely to use the given templates), this is a fair bit of overhead for seemingly-nebulous gains.
What you do in your video, however, is worse than both - you instantiate your subsystems as private nonstatic fields of Robot.java, but then fail to mention the (substantial!) ways the rest of the code has to change to accommodate this. The changes you make cannot simply be made in isolation. You cannot simply justify them by mentioning, in an abstract sense, how globally-scoped fields are undesirable in an OO language. You have to explain how, in this specific case, globally-scoped subsystems are a bad idea, and then explain how to use the framework if you change this. A team that naively tries to encapsulate their subsystems within robot.java without a solid understanding of what they’re doing is going to find it very difficult to write working command-based code.
It is true that globally-scoped subsystems make it a bit more annoying to unit-test your code. As far as unit testing code in an FRC context is concerned, this is the least of your problems - doing such is already a massive pain due to the tremendous amount of overhead required to write stubs for all of the dependencies. Properly-encapsulating your subsystems will not help this. I really do not recommend unit testing in FRC, for mostly this reason - it will not, on the whole, save you any time and effort, which is the primary purpose of adopting a tool.
The way OI is handled is indeed kind of bad, and does result in some teams every year snarling up the ordering of their static init. However, your complaint about students un-commenting the commented-out example code seems a bit spurious - if you actually read the comments in question, they’re clearly there to document the functionality of the Button class, and not as code that is intended to be un-commented and used in-place. Screensteps very clearly indicates that said code should be placed explicitly in OI’s constructor.
There are a lot of ways that template could be made better - in all honesty, I’d advocate removing the template entirely and instead increasing the number of example robots provided on the WPILib github, to demonstrate different ways to use the framework (global subsystems, singleton subsystems, private/injected subsystems, etc). But it’s extremely alarmist to claim that no one should ever use the CommandRobot template in its current state, especially when such a claim is mainly predicated on its apparent incompatibility with unit testing, of all things.
