New Button
How do you program the POV on the Logitech joystick to move one motor using lab view?
The POV value represents the direction the POV control is being pressed, in compass degrees. It’ll be -1 with nothing pressed. I think the Logitech will give values in 45 degree increments.
So what you want to do is wire the POV value to the select terminal of a case structure. If you want “up” to move the motor forward, add a case labeled “0” and put the code to run the motor forward in it. If you want “down” to move the motor backward, add a case labeled “180” and put the code to run the motor backward in it. Add a case named “-1”, make it the default, and put code to stop the motor in it.
Instead of doing a Motor Set inside each case, it would probably be better to just put motor speed constants in the cases, wiring them all out of the case block to a single Motor Set function.
