New mentor, need help with coding
Hi everyone, I just took over a team last year so this is my second year as a mentor, I have little to no coding experience and have been learning as I have been going. My team purchased a limelight this year to have our Robot line up with the high target. I have tried to use the documentation from the Limelight page (Case Study: Aiming and Range at the same time). I came up with this. Can anyone help to trouble shoot what I am doing wrong?
/* Copyright (c) 2017-2019 FIRST. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package frc.robot;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import edu.wpi.first.wpilibj2.command.Command;
import edu.wpi.first.wpilibj2.command.CommandScheduler;
import edu.wpi.first.wpilibj.PWMTalonSRX;
import edu.wpi.first.wpilibj.SpeedControllerGroup;
import edu.wpi.first.networktables.*;
 * The VM is configured to automatically run this class, and to call the functions corresponding to
 * each mode, as described in the TimedRobot documentation. If you change the name of this class or
 * the package after creating this project, you must also update the build.gradle file in the
 * project.
private PWMTalonSRX leftMotor1 = new PWMTalonSRX(0);
private PWMTalonSRX leftMotor2 = new PWMTalonSRX(1);
private SpeedControllerGroup left = new SpeedControllerGroup(leftMotor1, leftMotor2);
private PWMTalonSRX rightMotor1 = new PWMTalonSRX(2);
private PWMTalonSRX rightMotor2 = new PWMTalonSRX(3);
private SpeedControllerGroup right = new SpeedControllerGroup(rightMotor1, rightMotor2);
private DifferentialDrive m_Drive = new DifferentialDrive(left, right);
private XboxController driver = new XboxController(0);
private boolean m_LimelightHasValidTarget = false;
private double m_LimelightDriveCommand = 0.0;
private double m_LimelightSteerCommand = 0.0;
  private Command m_autonomousCommand;
  private RobotContainer m_robotContainer;
   * This function is run when the robot is first started up and should be used for any
   * initialization code.
  @Override
  public void robotInit() {
    // Instantiate our RobotContainer.  This will perform all our button bindings, and put our
    // autonomous chooser on the dashboard.
    m_robotContainer = new RobotContainer();
    //Compressor.start();
   * This function is called every robot packet, no matter the mode. Use this for items like
   * diagnostics that you want ran during disabled, autonomous, teleoperated and test.
   * <p>This runs after the mode specific periodic functions, but before
   * LiveWindow and SmartDashboard integrated updating.
  @Override
  public void robotPeriodic() {
    // Runs the Scheduler.  This is responsible for polling buttons, adding newly-scheduled
    // commands, running already-scheduled commands, removing finished or interrupted commands,
    // and running subsystem periodic() methods.  This must be called from the robot's periodic
    // block in order for anything in the Command-based framework to work.
    CommandScheduler.getInstance().run();
   * This function is called once each time the robot enters Disabled mode.
  @Override
  public void disabledInit() {
  @Override
  public void disabledPeriodic() {
   * This autonomous runs the autonomous command selected by your {@link RobotContainer} class.
  @Override
    m_autonomousCommand = m_robotContainer.getAutonomousCommand();
    // schedule the autonomous command (example)
    if (m_autonomousCommand != null) {
      m_autonomousCommand.schedule();
   * This function is called periodically during autonomous.
  @Override
  @Override
  public void teleopInit() {
    // This makes sure that the autonomous stops running when
    // teleop starts running. If you want the autonomous to
    // continue until interrupted by another command, remove
    // this line or comment it out.
      m_autonomousCommand.cancel();
   * This function is called periodically during operator control.
  @Override
    Update_Limelight_Tracking();
        double steer = driver.getX(Hand.kRight);
        double drive = -driver.getY(Hand.kLeft);
        boolean auto = driver.getAButton();
        steer *= 0.70;
        drive *= 0.70;
        if (auto)
          if (m_LimelightHasValidTarget)
                m_Drive.arcadeDrive(m_LimelightDriveCommand,m_LimelightSteerCommand);
          else
                m_Drive.arcadeDrive(0.0,0.0);
        else
          m_Drive.arcadeDrive(drive,steer);
  public  void Update_Limelight_Tracking(){
    final double KpAim = -0.1;
    final double KpDistance = -0.1;
    final double min_aim_command = 0.05;
  double tx = NetworkTableInstance.getDefault().getTable("limelight").getEntry("tx").getDouble(0);
  double ty = NetworkTableInstance.getDefault().getTable("limelight").getEntry("ty").getDouble(0);
if (driver.getRawButtonPressed(9))
        double heading_error = -tx;
        double distance_error = -ty;
        double steering_adjust = 0.0f;
        if (tx > 1.0)
                steering_adjust = KpAim*heading_error - min_aim_command;
        else if (tx < 1.0)
                steering_adjust = KpAim*heading_error + min_aim_command;
         double distance_adjust = KpDistance * distance_error;
          m_LimelightDriveCommand = steering_adjust + distance_adjust;
          m_LimelightSteerCommand = steering_adjust + distance_adjust;
How do you know there is something wrong?
What is the issue you are getting?
it doesn’t turn and align or distance it’s self from target
it doesn’t turn and align or distance itself from target
This looks wrong for one thing. Does it not move at all or just not aligning?
I had a feeling that was wrong because it wasn’t letting me put my 2 SpeedControllerGroups in place of the m_Limelight…
I am able to move the robot it just doesn’t do the auto aligning
please elaborate…
Please consider enclosing you code within triple backticks so that is is readable and CD doesn’t try to format it.
Eg
```java
System.out.println(“Example”);
Shows as
System.out.println("Example");
Better yet, consider using a link to a GitHub repository or gist or Pastebin.
I have a differential drive made up of 2 speed controller groups.
and
the documentation on the Limelight website has “m_LimelightDriveCommand” as the left drive motor and m_LimelightSteerCommand as the right drive motor. But when I go to do that with my 2 speed controller groups I get
Type mismatch: cannot convert from double to SpeedControllerGroup
Sorry I corrected it
So many issues here sorry. What you’re getting hung up on is likely the difference between arcade and tank drive. Are you familiar with that?
Yes, our robot is in Arcade drive
It doesn’t look like you’re ever setting the boolean m_LimelightHasValidTarget that gateways your tracking.
just added it
        if (tv < 1.0)
          return;
        m_LimelightHasValidTarget = true;
        if (tx > 1.0)
        else if (tx < 1.0)
If I understand your code correctly, the autotracking will only work if the driver presses button A and also has “left analog stick center pushed in”. It’s not clear why you need two buttons to gate this functionality. You might want to try changing the code to require only one button or even none.
Also, are you able to watch the limelight values on ShuffleBoard to ensure that they are what you expect? Can you also push m_LimelightDriveCommand and m_LimelightSteerCommand to NetworkTable?
