new motor
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Watchdog;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Relay;
public class Demonized extends SimpleRobot {
    private static final long TIME_DELAY = 1000; // in milliseconds
    RobotDrive drive = new RobotDrive(1, 2);
    RobotDrive spot = new RobotDrive(3);
    Joystick leftStick = new Joystick(1);
    Joystick rightStick = new Joystick(2);
    Joystick kicker = new Joystick(3);
    Watchdog fenrir = Watchdog.getInstance();
    Compressor fluffy = new Compressor(1, 1);
    void setUpRobot() {
        fluffy.start();
        fenrir.feed();
    public void autonomous() {
        setUpRobot();
        try {
            while (true && isAutonomous() && isEnabled()) {
                for (int i = 0; i < 4; i++) {
                    fenrir.feed();
                    Thread.sleep(TIME_DELAY);
                    drive.drive(0.5, 0.0);  // drive 50% fwd 0% turn
                    fenrir.feed();
                    drive.drive(0.0, 0.5);  // drive 0% fwd 50% turn
                    fenrir.feed();
                    drive.drive(0.0, -0.5); // drive 0% fwd -50% turn
            drive.drive(0.0, 0.0);  // drive 0% fwd, 0% turn
        } catch (InterruptedException ie) {
            // aaaaaaah, how do we log this out?
            // but make sure we stop
    public void operatorControl() {
        setUpRobot();
        while (true && isOperatorControl() && isEnabled()) // loop until change
            drive.tankDrive(leftStick, rightStick);
            Timer.delay(0.005);
            fenrir.feed();
            drive.arcadeDrive(kicker);
it does not like the second RobotDrive spot for some reasons.
any help.
I’m imagining that this doesn’t compile, since there isn’t a RobotDrive constructor that takes only one int parameter. Also, in operatorControl() you’re setting the drive motors based on input from two joysticks, and then setting them again based on input from a third joystick. This isn’t going to produce a desirable result.
If you want to control a single motor with a joystick, use the appropriate SpeedController class – Jaguar or Victor. RobotDrive is intended for use with drive trains that have two or four motor configurations.
Jaguar spot = new Jaguar(3);
        setUpRobot();
            spot.set(kicker.getY());
            Timer.delay(0.005);
            fenrir.feed();
got it working thanks
