How do you configure the new router? Can’t get ours to work.
I would try to follow the steps on the wpilib screensteps site.
If that does not work please reply where you are having trouble.
yes. the screensteps are helpful.
Also, if you got your radio as KOP. you do not have to flash the firmware. They needed to put that note in the screensteps a bit higher in the instructions list.
And another thing, make sure you have administrative rights on the computer you are trying to run the radio config tool on. you can also right click on the program and select “Run as Administrator”
Good luck. Let us know how it goes.
Russ
Mentor FRC Team 177 The Raptors
TC Central High School
Traverse City Michigan, USA
