I’ve been trying to program the tank drive for a couple days. All the motor’s firmware is updated and CAN IDs are matched…for some reason the motors won’t move at all.
/* Copyright © 2017-2018 FIRST. All Rights Reserved. /
/ Open Source Software - may be modified and shared by FRC teams. The code /
/ must be accompanied by the FIRST BSD license file in the root directory of /
/ the project. /
package frc.robot;
import edu.wpi.first.wpilibj.Spark;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.SpeedControllerGroup;
import edu.wpi.first.wpilibj.XboxController;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.GenericHID.Hand;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.drive.DifferentialDrive;
import com.revrobotics.CANSparkMax;
import com.revrobotics.CANSparkMaxLowLevel.MotorType;
private DifferentialDrive m_myRobot;
//private SpeedControllerGroup m_leftDrive;
//private SpeedControllerGroup m_rightDrive;
private static final int leftDeviceID = 0;
private static final int rightDeviceID = 1;
private static final int leftDeviceID2 = 2;
private static final int rightDeviceID2 = 3;
private CANSparkMax m_leftMotor;
private CANSparkMax m_rightMotor;
private CANSparkMax m_leftMotor2;
private CANSparkMax m_rightMotor2;
private Spark intake;
private Spark intake2;
private XboxController gamePad;
private Spark lift;
private DoubleSolenoid Solenoid_break;
private DoubleSolenoid Claw;
@Override
public void robotInit() {
- SPARK MAX controllers are intialized over CAN by constructing a CANSparkMax object
- The CAN ID, which can be configured using the SPARK MAX Client, is passed as the
- first parameter
- The motor type is passed as the second parameter. Motor type can either be:
- com.revrobotics.CANSparkMaxLowLevel.MotorType.kBrushless
- com.revrobotics.CANSparkMaxLowLevel.MotorType.kBrushed
- The example below initializes four brushless motors with CAN IDs 1 and 2. Change
- these parameters to match your setup
m_leftMotor = new CANSparkMax(leftDeviceID, MotorType.kBrushless);
m_rightMotor = new CANSparkMax(rightDeviceID, MotorType.kBrushless);
m_leftMotor2 = new CANSparkMax(leftDeviceID2, MotorType.kBrushless);
m_rightMotor2 = new CANSparkMax(rightDeviceID2, MotorType.kBrushless);
SpeedControllerGroup m_left = new SpeedControllerGroup(m_leftMotor, m_leftMotor2);
SpeedControllerGroup m_right = new SpeedControllerGroup(m_rightMotor, m_rightMotor2);
m_myRobot = new DifferentialDrive(m_left, m_right);
m_myRobot.setExpiration(Robot.kDefaultPeriod);
intake = new Spark(4);
intake2 = new Spark(5);
lift= new Spark(6);
Claw= new DoubleSolenoid(1,2);
//Solenoid_break= new DoubleSolenoid(1,2);
// Initialize a single gamepad controller
gamePad = new XboxController(0);
@Override
// Tank drive controlled with the left and right joysticks of the gamepad
m_myRobot.tankDrive(gamePad.getRawAxis(1), gamePad.getRawAxis(3));
// If the gamepad's right bumper is held, run the intake at 50% power
if(gamePad.getRawButton(6)) {
intake.set(0.5);
intake2.set(0.5);
} else if(gamePad.getRawButton(8)) {
intake.set(-0.5);
intake2.set(-0.5);
} else {
intake.set(0);
intake2.set(0);
//Elevator Lift
if(gamePad.getRawButton(5)) {
lift.set(0.5);
} else if(gamePad.getRawButton(7)) {
lift.set(-0.5);
}else {
lift.set(0);
//Breaking System According to the Binder
if(gamePad.getRawButton(2)) {
Claw.set(DoubleSolenoid.Value.kForward);
}else if (gamePad.getRawButton(3)) {
Claw.set(DoubleSolenoid.Value.kReverse);
