Ok so I am switching to Java and I am trying to deploy the code to the Robot. I have JRE installed on the Robot using the WPI Tool and I have the Code. When I go to “Run as” as per ScreenSteps it seems that everything is working fine, I get build successful but I do not get the Robot Code Green Light on the Dashboard, the dashboard is connected to the Robot, I am using USB to communicate with the robot in this process.
The lights on the RoboRIO are as follows: Power: Green (Given), Status: off, Radio: off, COMM: Red, Mode: off.
Note: the COMM light flashes ever once in a while. I also can access the Web GUI on the USB IP: 172.22.11.2.
The Console information:
Buildfile: C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build.xml
Trying to override old definition of task classloader
clean:
[delete] Deleting directory C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build
[delete] Deleting directory C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\dist
compile:
[mkdir] Created dir: C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build
[echo] [athena-compile] Compiling src with classpath=C:\Users\robotics1\wpilib\java\current\lib\WPILib.jar;C:\Users\robotics1\wpilib\java\current\lib\NetworkTables.jar;C:\Users\robotics1\wpilib\java\current\lib\opencv.jar;C:\Users\robotics1\wpilib\java\current\lib\cscore.jar to build
[javac] Compiling 5 source files to C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build
jar:
[echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
[mkdir] Created dir: C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\dist
[mkdir] Created dir: C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build\jars
[echo] [athena-jar] Copying jars to build/jars.
[copy] Copying 4 files to C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\build\jars
[jar] Building jar: C:\Users\robotics1\Documents\GitHub\5420-JAVA-Code-ROBOT-2015\dist\FRCUserProgram.jar
get-target-ip:
[echo] Finding roboRIO, please ignore any [hostinfo] error messages
[echo] Trying USB: 172.22.11.2
[echo] Trying DNS: roboRIO-5420-FRC.lan
[echo] Trying mDNS: roboRIO-5420-FRC.local
[echo] Trying mDNS: roboRIO-5420-FRC.frc-robot.local
[echo] Trying Static Ethernet: 10.54.20.2
[echo] roboRIO found at 172.22.11.2
dependencies:
[hostinfo] Error retrieving remote host information for host:roboRIO-5420-FRC.frc-robot.local.
[hostinfo] Error retrieving remote host information for host:roboRIO-5420-FRC.lan.
[echo] roboRIO image version validated
[echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
[sshexec] Connecting to 172.22.11.2:22
[sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
[delete] Deleting: C:\Users\robotics1\wpilib\java\current\lib
ative\lib\WPI_Native_Libraries.properties
[scp] Connecting to 172.22.11.2:22
[scp] Receiving file: /usr/local/frc/lib/WPI_Native_Libraries.properties
[scp] Receiving: WPI_Native_Libraries.properties : 2680
[scp] File transfer time: 0.01 Average Rate: 446,666.67 B/s
[scp] done
[scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties
[scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory
[echo] [athena-deploy] Copying code over.
[scp] done.
[sshexec] cmd : ldconfig
[sshexec] cmd : killall -q netconsole-host || :
[delete] Deleting: C:\Users\robotics1\wpilib\java\current\ant
etconsole-host.properties
[echo] Resolved mDNS to 172.22.11.2
[scp] Receiving file: /usr/local/frc/bin/netconsole-host.properties
[scp] Receiving: netconsole-host.properties : 132
[scp] File transfer time: 0.0 Average Rate: 132,000.0 B/s
[scp] done
[scp] done.
[echo] [athena-deploy] Starting program.
[sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
[sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 9 seconds
Versions:
DS: 17.0.1
RIO: FRC_roboRIO_2017_v8
Lib: Java 2017.3.1
PCM: 1.65
PDP: 1.40
Anything can help, Thanks Noah.
