niZeroconfService Error Event ID 100
Anyone know what’s causing this? Plastered throughout the Application tab of the event viewer of our Driver Station laptops is an error about niZeroconfService. The exact text reads:
"The description for Event ID 100 from source niZeroconfService cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Task Scheduling Error: Continuously busy for more than a second
The specified resource type cannot be found in the image file"
This error is repeated hundreds of times a second, basically whenever Driver Station is open. As far as I know it hasn’t caused any noticeable issues, but it is concerning. Any ideas?
