ERROR -44021 Resetting robot TCP CommsFRC: The size of the LED Color Array does not match the String Length. Driver Station
Do you have a riolog terminal that you can run, and not just driver station’s error messaging? What I’m trying to get at here is if there’s a type of error message before the million location messages…
Line 32 in ColorMatch.java is
private final ColorMatch m_colorMatcher = new ColorMatch();
Creating a ColorMatch object inside your color match class is probably recursive in a bad way, which is why the error is showing up a million times as it keeps trying to create an object of itself with ITSELF already inside. I hate recursion, its a headache lol. I don’t know how it would relate to an LED array error, but maybe take that line out to see what it would fix? Hope this helps!
Your issue is that you aren’t using the rev ColorMatch class, you’re using your own which leads to recursion which overflows the memory and causes the error. To fix this you need to add import com.revrobotics.ColorMatch;
Since your class has the same name, either set the type of m_colorMatcher to com.revrobotics.ColorMatch fully written out or rename your class
