No Communication to Driverstation
Hello! I am one of the coders for Team 293 SPIKE. My problem is that whenever my computer connects to the robot the Driverstation will not show it as connected. I have tried both ethernet and radio and it has had the same result. Although the Driverstation won’t connect every other FRC application I have tried has worked including Roborio Imaging Tool, Pheonix Tuner, VSCode and Shuffleboard. The only application that it doesn’t connect to is the Driverstation. I have disabled all firewalls on my computer and have reinstalled and repaired Driverstation but nothing has worked. Testing with other computers showed that the problem was limited to my computer.
Is the team number properly populated in the drive station? By default it will say team #xxyy.
No, I just added it in. I’ll check if it works in the morning when I get access to the robot again. Thanks!
