No glue... :(
Hi,
I heard that we aren’t allowed to use glue for anything on the robot. Just randomly I thought, what about PVC cement? Does PVC Cement fall under FIRST’s description of “glue”? Thanks to whoever is able to answer my question…
  • Josh
    “… who says we’re using pvc?” >_>
Who told you that, and did they quote a rule from the current manual? Adhesives are allowed (and glue is certainly an adhesive), provided that they: 1) are not used as traction devices (<R32>, last sentence); 2) follow <R33> rules on tape (labelling and insulating purposes only); and 3) are accounted for costwise if they are over $1. (Oh, and incidentally, you are using PVC. <R13> has details.) If you are still unsure–Q&A it.
thanks a bunch… it seems i need new, more reliable sources of information…
I was also under the understanding that glue was allowed, with the above cautions and also that it does not get on the carpet/floor. :slight_smile:
Well if glue wasn’t allowed I think there would be quite a few teams unhappy as they use plywood base robots… Ex. 173, 195 and I know there are others.
i have a bad experience with plywood. it is a good thing that the likelyhood of those robots forming sparks while moving is very small. oherwise…yeah, you know what I mean.
Well with the kind of electricity we’re dealing with, it wouldn’t be sparks that could be a fire hazard, but shorted out electronics. More than once a motor has belched flames in a competition, in that case you’d better pray you used fire-retardant plywood.
fireproof plywood?
Oh man, that Gorilla Glue does wonders.
i never heard of no glue
no glue is not a name, but means the absence of(no) glue
It’s what holds the B-2 Spirit and F-22 Raptor together…
are those military aircraft? man, no wonder they su-…turned out so great!
Hey now, lay off the B-2 and the F-22
Some of the best stuff in the air EVER. Enemies dead before they even know it’s there? Seriously. Now, the B-17 was sometimes glued…
i hope you mean to the ground. MUWAHAHAHAHAHAHAHAHAHAHAHAHAHA!!!
sorry about that. I usually get caught up in the moment like that, so don’t worry. I just love to ■■■■ people off. I usually intended to say “no wonder they fly so fast,” but I was tempted with my habit to ■■■■ people off and act sarcastic.
Haven’t seen that, but I remember two instances where it almost happened. First one–1999 at SVR. One of the robots started smoking (white, luckily–or not) during a match. Second one–Last year at LA. A rookie team had a robot that dumped tetras under the goals. Something happened, I’m not sure what. The robot got stuck in a goal and began spitting a shower of sparks about a foot high every time it tried to move.
Team 691 caught fire at SoCal a couple years ago, IIRC.
Even more ironic due to their name (Hartburn)
That doesn’t seem that bad. A senior on my team lit himself on fire…twice.
