We are trying to run the Dashboard. But everytime we try to, we get an error message saying that “ode.dll” does not exist. Any ideas on what we can do?
Somehow your dashboard seems to be dependent on the simulator.
If you go to your dashboard project window, see if you can find ODE.dll in your Dependencies. If you can’t find it, switch to the Files tab at the top of the project window, and I expect it to be at the bottom of the tree. If you show the ODE.dll in the Items view and then right click again you can select the menu item called “Why is this item …”. This will help identify what robotics stuff pulled in the physics engine.
If you have difficulties getting to the bottom of this, PM me and we’ll share files so that I can look directly.
Greg McKaskle
