No Robot Code/Com Issues
We have been trying to test our code, but when we try to deploy the robot code on the DS flickers between red and green. On the RoboRio, the com light was flashing from red to green, as well. We tried connecting via ethernet cable, but our code would still not deploy.
When you deploy code onto the robot, does it say this in the console
Build Finished
Are team went through the similar troubles. Here is a link to that https://www.chiefdelphi.com/forums/showthread.php?t=155295
Thx.
In answer to your question, we do see “Build Finished” in the console. After debugging our code, we now know that our code is crashing because of a segmentation fault. We found the source of the fault and are now working on fixing the problem. Thanks for your help!
