Using Windriver
Updates currently installed: Workbench, utilities, and driver station
Driver station displays connection and shows the firmware v43 is currently installed on cRio
We hit deploy on First<Deploy when using Windriver
No errors and displays in bottom - successfully deployed
We have checked in cRio and found the file
On Driver Station
Robot connection light green
Robot Code light still red (not found)
Continuously connects then disconnects
Try running a kernel task instead of deploying it and seeing if you get any errors such as an Unresolved Symbol. Are you using the new Command based methodology?
