No Robot Code
We are trying to add code to read the PWM of our Victors to find our deadband for our Victor class bounds. The code’s written, added to the robot code, but the Driver Station tells us there’s no code while the PWM reading code is in the code. We have deployed the code to the cRIO and have all the electronics set up. Here’s the code:
PWMReader.h:
#ifndef TEAM3138_PWMREADER_H
#define TEAM3138_PWMREADER_H
#include <WPILib.h>
#include <SmartDashboard/SmartDashboard.h>
#include <PWM.h>
class PWMTester : public PWM
public:
explicit PWMTester(UINT32 channel);
PWMTester(UINT8 moduleNumber, UINT32 channel);
virtual ~PWMTester();
void Update();
private:
#endif
PWMReader.cpp:
#include “PWMReader.h”
PWMTester::PWMTester(UINT32 channel) : PWM(channel)
PWMTester::PWMTester(UINT8 moduleNumber, UINT32 channel) : PWM(UINT8 moduleNumber, UINT32 channel)
And all we added to the Robot code was the line:
dash->PutNumber(“PWM Output”, m_PWMTester.GetRaw());
to print to the dashboard so that we can read the values off the screen. GetRaw() is found in PWM.h in WPILib.
The smilies shouldn’t be there. They should be a colon P.
Please use the code button when posting code snippets… Try removing the dash->putnumber (and potentially replacing it with a printf). Sometimes interacting with smart dashboard crashes the robot code.
#include <WPILib.h>
#include <PWM.h>
public:
void Update();
private:
#endif
#include <WPILib.h>
#include <PWM.h>
class PWMTester: public PWM {
public:
	void Update();
private:
#endif
#include "PWMReader.h"
PWMTester:WMTester(UINT32 channel) : PWM(channel)
PWMTester:WMTester(UINT8 moduleNumber, UINT32 channel) : PWM(UINT8 moduleNumber, UINT32 channel)
dash->PutNumber("PWM Output", m_PWMTester.GetRaw());
Click the button then paste your code inbetween .code] and
Okay. I’m new to Chief Delphi. So, do you have an answer?
Try removing the dash->putnumber (and potentially replacing it with a printf). Sometimes interacting with smart dashboard crashes the robot code. Also look at the netconsole/ WTX console output for errors.
Edit: as I look at it again, dash-> put number is never actually called. You have to put it in a function/constructor. I think you want:
void PWMTester::Update
I’m not sure if it was initialized somewhere else, but looking at this snippet, “dash” was never declared… Although I’m not exactaly sure what your trying to do here. The default victor class values should work, shouldn’t they?
The problem is that we’re trying to read the output values from smart dashboard. I’d like to try to get it to work with it, but I’ll try.
