Not able to connect with DS but able to deploy code
I am having a connection issue that only affects the Driver Station from connecting to the roboRIO. All my teammate’s computer’s do not have this problem. I am able to ping the roboRIO via command prompt and deploy LabVIEW code to the roboRIO-1094-FRC.local address over wifi. When I bring up the driver station the radio and roboRIO LEDs on the diagnostics page show green but I cannot get the communications LED (the one beside robot code) to turn green. I have tried wifi, Ethernet, and USB connections with no success. I have made sure my computer’s IP address is automatic and all network connections except the one in use are disabled. I do not believe I had this issue last year.
Any suggestions? Thank you!
Check to make sure you have the team number set in the driver station settings.
The team number has been set. I am not sure if I have tried re-typing it while I am trying to connect yet though. Thank you.
Also doublecheck your firewall is allowing the driverstation through.
